Results 1 to 8 of 8
Thread: What Should I Use Under Legs for Stability?
    Apr 2016
    San Antonio, TX
    16
    We recently set up our 14' x 26' x 52" Splash-A-Round AG pool. We hired someone to come out and level the area for us. That night, it started raining. ALOT! We are in south Texas and it rained for weeks on end. Once the rain stopped, he came back out and said he re-leveled and we were good to go. We then installed the 12" x 12" pavers to go under the legs of the pool making sure they were all at ground level and each paver was level to the other. We noticed the legs of the pool came to the back edge on several of the pavers but thought we would be ok. On one long side of the pool, the pavers were more in sand and on the other long side they were more on solid dirt. We filled the pool up and noticed that the pavers on the sand side sank a little but nothing to worry about. The pavers on the dirt side, however, started snapping in two and that side of the pool started to bow greatly to the point the legs in the center of the side were almost straight up and down. We have drained the pool. What do you recommend we use to help with the weight load on that side? We were thinking we should replace the pavers with some that are more heavy duty and possibly put a 2" x 12" on top of the pavers to help distribute the load. Opinions? I have pictures at the following photobucket site: http://s1172.photobucket.com/user/kp...w/Pool%20Issue
    11,740 gal., 14'x26x52" Splash-A-Round Summer Breeze AG Soft-Sided Pool, Waterway Clearwater II FD18 DE Filter, Waterway PH1100 1 hp pump, Hayward Diver Dave automatic cleaner, Taylor K-2006 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: What Should I Use Under Legs for Stability?
    Copy the IMG code and paste it into your post so that people don't have to click out of the site to see the pic. Many can't or won't. It will look like this
    Apr 2016
    San Antonio, TX
    16
    I'm not sure how to do that.
    38,342
    Welcome to TFP!!!
    Seems like we see a lot of broken pavers ...they are not really designed to handle point loads like this.
    If I ever had a pool like this (never have and likely never will), I think I would try to use something like redwood (rot resistant) or pressure treated 2x10 or 2x12s. As the wood would have a little give to it and not break.
    How To Post Pictures
    Apr 2016
    San Antonio, TX
    16
    Got it! Thanks!!!
    We are thinking of using the 2"x12" pressure treated wood for this season and installing a concrete border for next year.
    Jun 2016
    Kansas City MO
    23
    there's also 4" thick cement blocks instead of 2" 16 in. x 8 in. x 4 in. Concrete Block-30168621 - The Home Depot
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,813
    4" thick block is the way to go. That extra 2 inches makes a huge difference in strength. If you use lumber double up the 2x12 to get 4x12 pieces for all the same reasons you should use 4 inch concrete block.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Apr 2016
    San Antonio, TX
    16
    Thanks for all the help! We used the recommended blocks and all is great. Pool has been refilled and we are enjoying it!!
