- Jul 3, 2015
- 161
- Plaster
- Jandy Aquapure 1400
10:00 update: estimated 4 hour loss of 13.5 (pool starts getting full sun at 7:45) FC=35.5; added 7 bottles, threw dolphin in, kicked up pump to max again.
*Running into town to see if I can find a Taylor FAS-DPD refill kit so that I can test levels after adding chlorine, too, just to be sure we are indeed climbing back to shock level. Worried I'm gonna run slightly below shock level inadvertently, but if I test this frequently, I'm gonna run out of test chems before this evening. My thought was that if the noon test replicates the 10:00 test where rate of loss is concerned (3.4/hour), I would try adding two bottles at 1 to see if that helps to sustain the shock level during the high UV hours. . . If that works at 2, then I'll stretch the evening a bit longer by doing hourly adds without testing. . .
*Will vacuum this afternoon per "the plan," and will backwash when filter reaches 15, since start was at 12?
(Do you guys think I should continue posting these updates? My thinking was that in doing so, it may be helpful to someone else down the road. . . but I'm not sure if it may be more beneficially concise to just update at the end of the day, unless I have a question??? I guess I'm also doing this in case any of you spot something that sounds wonky as we go. . . Let me know--I want to honor the culture & norms of the forum as much as I can.)
Thanks again for all of your help & support!!!
