I just bought a foreclosure with a pool that's been sitting vacant (covered thankfully) since October 2014. Here's a picture of the setup, you'll notice a HST110 1 hp motor (matches with UST1102) that is frozen up and corroded, as well as a booster pump that's also frozen. The cleaner is gone, so I'm not so worried about the booster pump now. I'll probably get a robotic eventually anway.
I'm in south AL and we keep the pool open year round, so I'd like to upgrade to a dual speed motor. I've read as much as I can find on the forum and I'm hoping someone confirm that this motor http://www.inyopools.com/Products/00200017003498.htm will be compatible, and that I'll just need to wire in a 3-way light switch between the timer and the motor to control the Hi-Low feature of the motor? Everything I've read says that the SWG will function fine with the motor on low.
Any help is greatly appreciated. Bonus pic of the pool immediately after it's two year "unveiling".
