Results 1 to 1 of 1
Thread: Want to change the drain cover & frame in vinyl pool
    Jun 2016
    Tallahassee, FL
    1
    Hi Everyone - new member here, posting my first thread. Are there any issues with changing out the drain covers (including the frames) on a vinyl liner pool after it's filled? I'm thinking not, since I seem to remember the pool guys cut those in after it had started to fill up, but I wanted a group opinion on it. I have the gear to be able to sit on the bottom and do it, just wondering if messing with the frames might cause leaks. I want to change them from their current beige color to dark gray, to blend with the liner. I already changed out all the jets and they look great - basically invisible Thanks for any and all input!
    New construction in-ground vinyl pool in 2015: oblong ~ 15,600 gallons - salt system - Hayward DE filter - Pentair IntelliTouch panel (with remote capability) & IntelliChlor IC 40 - Polaris Black Max 280 cleaner.
