Thread: Best SWG for 30' above ground pool
    Jun 2016
    Murfreesboro
    4
    Howdy,
    I'm new to TFP, but after a few years of trying to half use my pool, I'm ready for a change.
    I have a 30' above ground circular pool with a sand filter and 2 speed pump.
    I'm currently running Pristine Blue, but would like to change to salt. All of the generators I've seen for a pool that size show as being for an inground pool. I don't know if that matters or not, but I thought I'd seek help from the experts.
    Thanks!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Best SWG for 30' above ground pool
    If your water depth is 4 feet, you've got 20K gallons. The general guideline recommended here at TFP is to oversize your SWG cell by 2x your pool volume. This allows you to run the SWG for less time each day, reducing pump run time and extending the life of your cell. Look for an SWG that's rated for 40K gallons. Doesn't matter if you have a IG or AG pool.
    This is a nice market comparison page for SWG: Full Market Comparison of Salt Water Chlorine Generators for Swimming Pools
    For your pool, using 20K gallons, look for an SWG system that produces about 1.4 pounds of chlorine per day or better.
    Welcome to TFP!
    Too bad your username didn't get put to good use over in Britain!
    Isolated Spa - 345 Gallons
    38,305
    I should change my name ... PoolyMcPoolFace has a nice ring
