Results 1 to 8 of 8
Thread: Decking on hold until next summer?
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    Since we are getting our pool installed at the end of the season we are considering waiting until next spring to do the decking. We think we'll pour the minimum concrete around our pool right now (4ft around it) and then next season do the rest. We are doing this so that the ground can settle over the winter and also because next summer our budget would allow us to do more with landscaping and decking than this year.
    We are wondering if we add more concrete later if it would look odd--having two separate pours...one being a season older. We also thought of starting over next year and doing pavers....Or would it be best to just do all the decking now (although it wouldn't be exactly how we want it)? Any advice would be appreciated.
    I'd like to see pictures from people who added more decking at a later date if anyone has done so. Thanks!
    IG Vinyl Mountain Pond 22x36/ Depth: 3'4"-6'6"/ About 19,000 Gallons/ Pentair/ Clean&Clear Plus420/ Intellichlor IC40/
    Easy Touch/ Intellabrite 5G LED Color-Changing Light/ DeckJetsII/ S.R.Smith slide
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Re: Decking on hold until next summer?
    Highly recommend doing it all at once to avoid a different appearance. Leaving it without decking this year is no problem except for the mess factor.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    wjr75's Avatar
    Jun 2013
    IL
    836
    We have stamped concrete around our pool and have pavers extended off the stamped concrete to the outdoor kitchen and fire pit. So yes, that combination is doable.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Yes, I'd agree for different types there is no difference now or later.
    Real question is what do you want for decking then consider what options are best for that selection.
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    Another option if you're willing to do a stamped overlay is pour the minimum deck now and leave it unfinished concrete, add the remaining deck next year and apply a stamped overlay to both. The below shoes mine with a 3 year difference in pour time between the slab under the covered patio and the new pool deck. There obviously is a break as they're two separate slabs but I do not notice it at all and the finish is identical as they were finished at the same time.
    And a comparison to show the two different slabs pre overlay:
    38'x24' freeform IG gunite, 26k gallons, 3.5' - 7'
    8t Moss rock waterfall with gunite slide
    SWCG, 2 x 2.7hp Hayward Tristar pumps, booster pump, 425 sqft cartridge, 400,000 BTU heater, Polaris Black Max 280, ProLogic PS8 & Aquapod
    Jul 2015
    Central Valley CA
    1,107
    If you want to do 2 pours of concrete you could color the 4 foot you are doing now lighter, darker or even a different color altogether than the second pour that will make it look intentional and you can end up with an interesting contrast. If your PB uses computer aided design they should be able to do a few renderings with different options so you can get an idea of what it will look like.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    May 2013
    Needham, MA
    140
    You should also come to terms with the idea that all the decking may end up being done next year. PB delays can be quite common and, weather may play a factor as well. Not trying to be a buzz kill but I have never had any major project not have a few bumps in the road.
    14x28 Kidney IG vinyl pool, 9250 gallons. Pentair 1.5hp superflo variable speed, Pentair Clean and Clear 240 Cartridge filter, Pentair IC40 SWCG, Hayward Heatpro 110,000k heat pump, Pentair Intellibrite 5G LED lights, Polaris 280, Taylor K-2006 test kit
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    Quote Originally Posted by atttech-2 View Post
    That is a great idea that I haven't thought of! Our PB doesn't do the computer design, but I bet it would look nice with contrasting colors! Thanks for the tip!
    Also, cbink-your decking looks great! I love that!
    Quote Originally Posted by rmclain73 View Post
    Not a buzz kill! We aren't in any hurry! Lol!
