Thread: changing out the covers on the bottom of the deep end
    Jun 2014
    Houston, Texas
    475
    When we had our pool replastered in May, they put a different cover over the filter thingees in the deep end. As a result, our Shark keeps getting stuck on them. the PB gave us new ones but any ideas how to change them out? it's 7 feet down and we are NOT draining the pool!
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,740
    Re: changing out the covers on the bottom of the deep end
    Hold your breath!!!
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Jun 2014
    Houston, Texas
    475
    Yeah right. Hasn't thought of that
    19k SW IG
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Quote Originally Posted by DMS2014 View Post
    Sent from my iPad using Tapatalk
    You can rent scuba gear maybe if it can't be changed quickly. Probably not necessary but definitely an option.
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,740
    I'd use a garden hose as a snorkel
    -Brian-
    POOL BUILD
