Results 1 to 11 of 11
Thread: Hello, New to Trouble Free Pool!!
    Jun 2016
    Allen Texas
    11
    Red face Hello, New to Trouble Free Pool!!
    I live in Allen Texas, I just learned about trouble free pool. I just started using a TF-100 test kit! I do my best to take care of our pool. Buy my products from local family owned pool store, which can get expensive, especially in spring when trying to get rid of algae & balancing the chemicals.
    Im interested in starting the BBB method. Do I have to do anything special to switch to BBB method, can I start immediately?
    Looking forward to learning alot here!
    approx 17,000 in ground gunite
    over 25 years old, coping and plaster redone 10 to 11 yrs ago
    old pac-fab 60 sqft de filter, grids(not cartridge kind)
    280 polaris/ Test Kit-TF-100
    Live in Allen, Texas
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hello, New to Trouble Free Pool!!
    Welcome to TFP
    armed with a TF100 you are good to start now
    Get bleach/liquid chlorine from walmart or HASA dealer if you have one near you.. use poolmath above to input your numbers from the TF100 tests.. If you want you can post them here so we can help the first time..
    Keep reading and go through pool school and ask any questions you have
    Jun 2014
    15,107
    The plain/regular HEB "Bravo" or Wal-Mart "Great Value" bleaches work really well. Sometimes Wal-Mart has their "Pool Essentials" 10% bleach in the pool section as well. Welcome to TFP!
    30,419
    Your first step is to break out that TF-100 and post a set of test results. Also tell us how your water looks.
    Then, read "The ABC's of Pool Water Chemistry" up in Pool School
    Jun 2016
    Allen Texas
    11
    Quote Originally Posted by cowboycasey View Post
    Welcome to TFP
    Thank you!!!
    Pool test is showing
    ph-7.8
    fc-1.5
    cc-0
    cya-20
    alk-90
    I do notice a little algae in the pool on tile going to skimmers.
    Jun 2016
    Allen Texas
    11
    Ch was 675, our local pool store said not to worry about that unless it's gets into the thousands. We do have some white build up around tile.
    Jun 2014
    15,107
    Good post. So you already confirmed one thing, and your low FC supports it .. algae. At TFP we have "SLAM" instruction to show you how to remove algae (link below). Read that page and do everything listed and you'll do fine. A couple reminders:
    - Lower pH to 7.2 first
    - Add another 10 ppm worth of stabilizer to your water to make your CYA 30.
    - Increase your FC to "12" using regular bleach (HEB-Bravo or Wal-Mart- Great Value is fine.
    Focus on testing FC somewhat frequently to maintain that FC level until you pass the 3 SLAM criteria on the SLAM page. AFTER the SLAM, when you've passed all 3 items, consider raising your CYA to around 50 to protect your FC from the sun. The never let the FC drop below 5. Hope that helps. Let us know if you have any more questions. Good luck!
    We'll worry about this later. Stay far away from the pol store. YOU'RE in charge now.
    30,419
    Once you start your SLAM, don't be shy about brushing. It may even cloud up your pool a bit but it is important to do that to kill all the algae.
    The SLAM article is very complete but you must follow it to a T.
    Jun 2016
    Allen Texas
    11
    Thanks for the info, however yesterday I didn't mention that my pool water is very blue and clear. I dont see any signs of other algae besides black around the inside tiles to the skimmers and some on light fixtures and tile around steps, not a whole lot of it. I did the chlorine drop test just a few mins ago
    , FC-1, CC-0. I added 24oz of stablizer yest in stocking, placed in skimmer basket, and it still hasnt dissolved all the way. With chlorine being low, do i need to wait on cya before i slam? And yes, i wont be shy about brushing!! I purchased concentrated clorox at 8.25%, and it says on bottle available 7.85%, not sure what the other ingred. is. Eager is get started!!!
    I forgot to mention that ph is down to 7.2 today, using the basic k-1000 in the TF-100 kit.
    Jun 2014
    15,107
    No need to wait for all the stabilizer to dissolve. Squeeze the stock to help it go faster though. Increase FC to 12 and do your best to maintain it consistently. Good luck on your SLAM.
    Jun 2016
    Allen Texas
    11
    Thanks!
