Results 1 to 7 of 7
Thread: Sod removal for install
    Hello!
    Newbie here trying to do an install for an 18 ft above ground pool.
    I was wondering if there is any easier way to remove sod other than using a shovel and a sledge hammer?
    Thanks
    Christine
    18 X 54 Round-Wilbar-Sharkline Above Ground Tahitian
    Stainless steel access panel/ 1.5 hp pump
    Self Installed 6/09
    Crushed by Irene, and a 50ft oak 8/28/11
    Re installing 4/12 and up and running
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Sod removal for install
    Depending on your soil, watering the ground may help. You may also be able to rent a sod-kicker or a sod-cutter from a tool rental place. Both are much easier than a shovel, but can be hard to manuver in tight areas.
    Guest
    Rent the sod cutter from your local tool rental place.
    It is worth the money because it makes it so much easier.
    Thanks for the suggestions.
    We are going the less expensive route and having son in law coming over to help
    It really isn't that large of area, so I think between the 3 of us we can so this.
    Really glad I found this forum, though. We are some what new to the "pool scene", although I have had an Intex pool for nearly 10 years. But, I always drained it each season, I have never winterized a pool before. Or installed one either for that matter. I have no idea about PH, and all the other chemical stuff either. I just kept HTH tabs in the floater and added algicicide once a week, cleaned the filter when necessary and ran my Pool rover on the bottom to keep it clean. I sure hope I can keep this one clean as well.
    Really looking forward to having this pool installed and out of the boxes!
    Christine
    Self Installed 6/09
    DaveNJ's Avatar
    Toms River, NJ
    520
    "Pool School" at the top of page is a great place to start. The articles answer alot of questions. A good test kit is worth its weight in gold. I prefer the TF100, link in my signature.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Thanks for the info!
    I will definately look into the test kit as I am going to need to purchase one. With this offered kit, is some kind of a chart included to see where your readings are supposed to be? I need all the help I can get
    But, don't want to put the "cart before the horse". We finally got all the sod removed this past weekend with a pick ax and shovels. That was a LOT of work. Now hubby is perfecting his leveling of the site so it isn't bumpy and the dirt is all hard, smooth and level. Hopefully, we will be ready for sand this upcoming Saturday!
    Christine
    Self Installed 6/09
    DaveNJ's Avatar
    Toms River, NJ
    520
    Use the The Pool Calculator, link on the Home Page. Enter your pool size (gallons) and select Select Goal Levels at the bottom. The fields will show up with the appropriate range for each test. Get familiar with the calculator ahead of time. Enter some numbers say Cl 0 in the first field and 5 in the second. You will get the idea. Its an invaluable tool.
