Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Pool water issues
    May 2012
    Henderson, TN
    232
    Pool water issues
    Well, after years of having crystal clear water, we now have a problem. The water was great last week. It's been very dry and the farmers and mowers have kicked up and there was more dirt than usual in the pool. So my wife went out and vacuumed the pool and brushed the walls. Afterwards, she forgot to backwash and rinse the filter. Every since then, it has steadily gotten worse. Just looking at the water, it looks green but if I take a cup of water out, it's not green. So I hoping it just looks like that because of all of the dirt. I tested the chlorine this morning and it's down to 1.5. I have started vacuuming to waste to get the dirt out. The deep end is so bad you can't see the floor or the vacuum head.
    So I have a couple of questions:
    -Do I need to have the filter running in between vacuum sessions or will that just make it worse stirring the dirt up? I ask because then I could run the salt generator to help bring the chlorine level up
    -Should I add bleach to bring the chlorine to shock level?
    35000 gallons
    Hayward Sand Filter
    Jandy AquaSeries Ei Pure Salt System
    IG
    Pentair Superflow 1hp
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Pool water issues
    1. You want to filter out what you can't vacuum up, so stir away.
    2. Absolutely. You need to get the FC to target, and never let it fall below minimum Pool School - Chlorine / CYA Chart
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2015
    Central Valley CA
    1,107
    If it has a green tinge, is cloudy and loosing 1.5 ppm over night it's time to SLAM. Better to start now than let it get to far out of control. I don't have any landscaping around my poo it is all dirt that we are in the process of removing rock from a lot of shoveling and raking. As a result I get a lot of dirt in the pool but the water is clear just gritty, green is most likely algae.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    May 2012
    Henderson, TN
    232
    So what if the filter doesn't filter this dirt because it's so fine. It just gets through the filter and back into the pool. That's one reason I am vacuuming to waste. The only reason the FC is that low now is because I have had the pool off to allow the dirt to settle to get it out
    35000 gallons
    Hayward Sand Filter
    IG
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Simply running the pump shouldn't stir up the dirt that much. Even still, I would add chlorine with the pump running for 30 minutes, then switch it off and let the dirt settle. I'd also try to gently brush it toward the bottom of the deep end to minimize vacuuming area. Repeat.
    May 2012
    Henderson, TN
    232
    Quote Originally Posted by atttech-2 View Post
    If you take that dirt, break into fine particles, and brush it around, the water will be more than just gritty and clear. That's where ours started. The water was clear and not even gritty. It just had the dirt on the floor of the pool. Until my wife brushed it all around and stirred it up. But yeah, I will have to test to see if it needs to be slammed. The pool has been completely off for the better part of two days and the chlorine has only dropped to 1.5 during this time
    Quote Originally Posted by Mr Bruce View Post
    Sounds good. I'll start on that now. Thanks.
    35000 gallons
    Hayward Sand Filter
    IG
    TomGallopavo's Avatar
    Apr 2016
    Hillbillyville, MO
    160
    Agree with slam but I have read on here some people add DE to the sand filter. I don't know if you can do that but it might be worth investigating if you have so much clay in your dirt over there.
    Spring 2016 Install, 24'x54" Saltwater LX AG Round Pool (13500 gal.), AquaPro 200 SQ. FT. Cartridge Filter System 2-HP 2-Speed Pump, Solaxx Saltron Retro Jet RJ Saltwater Chlorine Generator, Aqualuminator Above Ground Pool Light, TF-100 Test Kit w/ Borate and Salt, Well Water.
    May 2012
    Henderson, TN
    232
    Quote Originally Posted by TomGallopavo View Post
    Agree with slam but I have read on here some people ad DE to the sand filter. I don't know if you can do that but it might be worth investigating if you have so much clay in your dirt over there.
    I actually have some DE but have not taken the time to add any this time. I will after this though
    35000 gallons
    Hayward Sand Filter
    IG
    May 2012
    Henderson, TN
    232
    So I started the SLAM process today. I got the pool to a shock level of 28 (my CYA was where it should be so I had to bring it up a lot). It dropped a little this afternoon and the water cleared up a lot as well. So I added more bleach and just checked it again at sun down and I'm at 29.
    I just want to double check the next part. I turned the SWG off obviously so it won't make any chlorine tonight. But can I leave the filter running all night to help get some of this stuff out of the pool? Or does EVERYTHING need to be off for the SLAM process??
    35000 gallons
    Hayward Sand Filter
    IG
    Aug 2014
    Northern IL
    4,615
    During a SLAM, you want your pump running 24/7.
    Apr 2014
    Hackettstown, NJ
    35
    Re-read the SLAM process again, I believe it says pump on 24/7 Filter when possible, otherwise just recirculate.
    25.5K gal vinyl IGP 3.5' - 8' depth. 1.5HP single speed A.O. Smith C48L2N134B1 motor on a Hayward SP2610X15 Pump. 40 ft2 D.E. Filter Hayward model EC75A. Hayward Chlorinator model CL200. single skimmer, 2 Returns. TF100 Test Kit/Speed Stir.
    May 2012
    Henderson, TN
    232
    Quote Originally Posted by MarianParoo View Post
    Quote Originally Posted by DHoover85 View Post
    That's what I thought. Thanks
    35000 gallons
    Hayward Sand Filter
    IG
    Aug 2014
    Northern IL
    4,615
    Good luck!
    May 2012
    Henderson, TN
    232
    The water is pretty much back to normal. The OCLT showed a drop of 1.5, so I guess I'll continue on today. I have been vacuuming, brushing, and cleaning the filter pretty often as well.
    35000 gallons
    Hayward Sand Filter
    IG
    May 2012
    Henderson, TN
    232
    Tried adding pics but didn't work.
    35000 gallons
    Hayward Sand Filter
    IG
    May 2012
    Henderson, TN
    232
    What's the highest level of chlorine that is okay to swim in?
    35000 gallons
    Hayward Sand Filter
    IG
    May 2012
    Henderson, TN
    232
    I just checked the chlorine again. It is now 23.5 with a CC of 0.5. The water is clear. Do I need to continue with the SLAM to see if the OCLT gets better tonight? It was a 1.5 drop this morning.
    35000 gallons
    Hayward Sand Filter
    IG
    Aug 2014
    Northern IL
    4,615
    TFP says that it is safe to swim at just below shock level and when you can see a swimmer in trouble.
    Yup, continue on until you pass the OCLT.
    May 2012
    Henderson, TN
    232
    Okay. So if I pass the OCLT in the morning, then it will most likely be safe to swim that afternoon? I'm for sure going to continue the SLAM...that was a question I already knew the answer too
    35000 gallons
    Hayward Sand Filter
    IG
  20. Back To Top    #20
    Aug 2014
    Northern IL
    4,615
    It should drop enough by afternoon if you pass the OCLT.
