Results 1 to 9 of 9
Thread: High CC this morning
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Good morning! I test everyday at this time of the morning, after my pump has been off all night. I run the pump for an hour in the morning before I run the tests. My FC was 6, as it has been every morning but my CC was 1 today. CYA at 70 and water is clear. Could it be the water is just not mixed good, or should I consider something else??
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: High CC this morning
    You should always test after letting the water mix for awhile, 20-30 minutes.
    Do an OCLT at ~10 FC tonight to see if you need to SLAM.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2015
    Central Valley CA
    1,106
    Did you check the skimmer, perhaps you have a dead critter in there?
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    No dead critters this morning. My FC has never dropped below 6. I brush twice a week and vacuum at least that much.
    Mark
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Went to town and left the pump running with SWG off for a couple hours, and came home and retested and CC was 0. FC still at 6.
    Mark
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    You are probably fine. You could do an OCLT to confirm, I bet you pass easy.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Thanks Mr. Bruce, I will be doing one tonight. Can I do it at my present level of 6, or do I need to go to 10 on the FC?
    Mark
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    10 is better, will show a larger % loss than 5-6. SWG off, pump on!
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Ok thanks!!
    Mark
