Thread: iAqualink 2.0 programming question
    Jul 2015
    Santa Clarita, CA
    22
    Got everything installed today and went to program it and kind of stumped myself. On my old system programmed with my PDA I had the pool mode come on from 9am to 4pm and during that time frame from 9:35am to 10:35am I had the VSD speed set to 3250 RPM on a cleaner mode. In looking at the setup I cannot figure out how to get the same mode of operation with the new system.
    Anybody know if this can be done with the 2.0?
    Thanks Steve
    In ground concrete with pebble tech finish, with attached spa, Intelliflo Pentair VSD pump, iAqualink 2.0 Jandy control system, Pentair pool heater, Hayward salt chlorine generator and a Pentair 4000 series filter
    Dec 2014
    Houston, Texas
    134
    Re: iAqualink 2.0 programming question
    It's a line item under the system set-up called VSP set-up. You can also call Jandy and they can walk you through the set-up process as well. Their number is 800-822-7933.
    GL!
    Jul 2015
    Santa Clarita, CA
    22
    Figured it out....pretty simple works great!
