Results 1 to 11 of 11
Thread: What is the name of the shape of my pool? Want to fill out my sig correctly
    May 2016
    Tallahassee
    71
    I have never seen another pool shaped like mine, and I found a picture of it....Is there a common name for a pool with this shape????
    It is the one named 'Muskoka' in the picture....its essential oval at one end and square at the other end...
    38,254
    Re: What is the name of the shape of my pool? Want to fill out my sig correctly
    We really do not care what you call it. We just want to know the surface type and volume
    May 2016
    Tallahassee
    71
    I would still love to know what to call it...People ask me what shape the pool is (pool stores, etc etc) and I say 'uhhh, its like oval on one side and square on the other, kinda?'
    38,254
    There are only about a handful of those pools where if you gave me the name I would know the shape.
    It's a keyhole - sort of.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    I've heard of the Capri shaped pool which I thought was like that....and I've also heard of the Patrician which is like a roman on one end and squared on the other....Maybe one of those?
    But then again capri could also be like a mountain pond too..I agree w/ Geebot...I think it's most like a keyhole.
    IG Vinyl Mountain Pond 22x36/ Depth: 3'4"-6'6"/ About 19,000 Gallons/ Pentair/ Clean&Clear Plus420/ Intellichlor IC40/
    Easy Touch/ Intellabrite 5G LED Color-Changing Light/ DeckJetsII/ S.R.Smith slide
    May 2016
    Tallahassee
    71
    keyhole is probably as close as I am going to get to describing the basic shape...although the images of the keyhole pools seem to show the circular part much larger....uhh, like a keyhole lol....but at least the basic principle gets conveyed....
    Quote Originally Posted by Crickets View Post
    it's closer to a keyhole then the other two....but I must say, I really like the way the patrician style looks...
    20k Gunite 16' x 32' , Hayward c7030 700 sq ft cartridge filter. Pentair Superflo 1hp 2sp pump, Intellichlor IC40 w/ Power Center SWG, Hayward GL-235 Solar Controller, (2) Digital GE Timers.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,802
    I couldn't have a pool with the shape of that picture.
    For your pool I'd say ovaltangular.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    LOL @ ovaltangular, pretty sure they skipped that one in elementary school And what the heck is a Muskoka! Keyhole definitely fits it best.
    Ooh, I like the Venetian, do that one
    Swim ready :) My Pool Build Thread. IG shotcrete 34x16 Grecian shape. 22k gallons. 3'6 - 8'6 deep. 12x5 Baja ledge w/ 2 Bubblers, 14' raised beam sheer descent waterfall in stacked rock. Custom stone diving board. Hayward sand filter, VS pump, Aquarite T-15 SWCG. A&A In floor system w/ Gamma 4 venturi heads, Blue surf Pebble sheen, Colorlogic LED. Future Travertine Sandcastle Owner.
    Aug 2014
    Houston tx
    2,524
    Bmore, you made me spit out my coffee!!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    No, it's Ovaltine
    but seriously, someone else on this forum is rehabing a pool in the same shape and he called it a keyhole.
    Dolphin E10 Cleaning Robot.
