Thread: Determining pool volume
    Jun 2016
    El Paso, TX
    38
    Ok guys i have gone through various calculations, calculators, formulas but i was hoping i could get help! First of all here is a pic of my pool, i cant determine if its free form, oval, kidney or what! Anyhow i took the depth in 6 places and the average depth approximately 5.5ft. We were under the impression pool was 9ft deep but water comes up only to 7.5ft and shallow end 3.5ft.
    Length of pool is 32ft
    Width at deep end is 11ft
    Width at shallow middle is 16ft
    with at shallow end is 9.5
    Can someone help me calculate this! I know we have gone thinking is 20,000 gallons all of this time, but all my calculations come out wayyyy shorter, thanks guys!
    Jun 2016
    El Paso, TX
    38
    Re: Determining pool volume
    Heres a better pic! Sorry
    Feb 2015
    Chandler AZ
    922
    Hi, welcome to TFP!
    Congrats on ordering your very own TF-100 testkit.
    You can use the "Estimating pool volume" section in PoolMath. I could do it for you, but you will need to become familiar with PoolMath anyway - and there's no time like the present.
    I'd use an average width of 11 feet, depth of 5.5 feet and the length you listed. Also, use the OVAL option for shape. That should be a good ballpark starting point - you can adjust up/down as needed based on careful additions of chemicals and testing 20-30 minutes later with your TF-100 to see if you attained your PoolMath calculated goals.
    BTW - nice dog!
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Jun 2016
    El Paso, TX
    38
    Quote Originally Posted by proavia View Post
    Hi, welcome to TFP!
    BTW - nice dog!
    Thank you! Will do! And Sparky says thanks!
    Jun 2016
    El Paso, TX
    38
    So according to pool calc my volume is 14,000 gallons! Will determine when i get kit i assume
