Results 1 to 10 of 10
Thread: Remodel Intex skimmer?
    LittleTagAlong's Avatar
    Jun 2016
    Amarillo TX
    119
    Since I am in Texas and we have wild temp swings, the ring on my easy set changes size at least twice a day. Any time I turn the sand filter on, if I'm not standing there, the skimmer pops up and sucks air. tired of purging air. I'm also concerned about burning up filter. Right now I have a 5 lb weight tied to the outer bucket with a length of trot line. I would love to have a floating skimmer but can't afford one. Any ideas on how to engineer from bits and pieces?
    AG, Intex 18' x48" Easy Set pool( =/- 5455 gal)
    Intex SF80110 sand filter & SWG ECO 7110, Hayward AquaCritter
    Well water, location is north Texas, usually up from late May to Oct.
    Taylor TF-100 test kit, TDS Digital Salinity meter and Taylor salt kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Remodel Intex skimmer?
    Could you post a picture, maybe we can get a better idea of what is happening
    Jun 2016
    Amarillo TX
    119
    [IMG
    He milk[ATTACH]51235[/AT
    TACH]]http://uploads.tapatalk-cdn.com/20160630/9a531278e0ab32d0a5a71a21616c93db.jpg[/IMG]
    Jun 2016
    Amarillo TX
    119
    Sorry, still figuring out how to use this app
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    I seem to recall someone else having this problem a year ago. They built an external stand from PVC that held the skimmer. You might search for that here, or see if you can come up with something similar on your own.
    Found it: Secure mounting Intex skimmer
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2016
    Midwest City, OK
    2
    Unless you have an Intex pool, the skimmer will not fit on the stock strainer. I had to manufacture an adapter.
    Jun 2016
    Amarillo TX
    119
    I think this has given me an idea. I'm going to try to make "a boat" for the skimmer from PVC. Will post pics and supply list, if successful. 😉
    Jun 2016
    Amarillo TX
    119
    Quote Originally Posted by Domram9 View Post
    Sent from my Z970 using Tapatalk
    I DO have easy set intex
    Jun 2016
    Amarillo TX
    119
    My idea sunk. Lol
    Jun 2016
    Amarillo TX
    119
    The idea was to make a float for the skimmer. Just couldn't get it to balance.
    Back to trot line and barbell weight.
