Results 1 to 9 of 9
Thread: Algae inside bubblers
    Mar 2014
    Angleton, Tx
    91
    I have had pool up and running for just less than and year. No issues until now. I noticed green around the bubblers and decided to pull them out. That's when I found the culprit that was eating my FC.. Should these be removed and cleaned on a regular basis? Or do y'all run your bubblers regularly? It doesnt appear they get alot of water circulation under the light/cavity to prevent the algae buildup. Any suggestions appreciated. Thanks
    IG Pebble sheen blue surf approx. 14k gallon, beach entry, 7' spa, 3.5 ton jumping rock/waterfall, Pentair 2hp whisper flo, booster pump, 520 cartridge filter, Stenner Econ T, 400k master temp heater, easy touch controls,TF-100 w/speedstir
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Algae inside bubblers
    You should not have to clean them very often if proper FC is maintained at all times, based on your CYA and method of chlorination. I would recommend inspecting them periodically, especially when opening the pool in the spring and after any time that proper sanitation has lapsed. Use a toilet brush (dedicated for pool use only! ) to scrub inside the open housing when inspecting.
    Isolated Spa - 345 Gallons
    Mar 2014
    Angleton, Tx
    91
    Sounds good, that's what I used to clean them this time. CYA is at 40 and I dose manual with bleach. Slaming now! Thanks!
    Mar 2014
    Angleton, Tx
    91
    is it possible to have an algae issue and still show 0 on cc reading? Readings as followed.. That's why started looking for the culprit. Went from 6-7 FC on 6-28-16 @9am to .5 FC checked @ 5pm on 6-29-16
    FC- .5
    CC- 0
    PH- 7.5
    CH- 250
    TA- 100 (was at 70 when Borates were added, slowly crept up)
    CYA- 40
    Borates- 50
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    It's likely since your FC is WAY below minimum for CYA of 40. Pool School - Chlorine / CYA Chart
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mar 2014
    Angleton, Tx
    91
    Quote Originally Posted by Mr Bruce View Post
    correct, but it was fine until yesterday. I check daily and loose usually around 2ppm fc until this big drop. Ill continue to slam, just didnt want to miss anything. Thanks
    Mar 2014
    Angleton, Tx
    91
    So i officially started slamming on 7-4. The only visual algae was in the bubblers which were cleaned out. I have taken out all the lights, and scrubbed inside the skimmers and all around the rock water fall, brushing daily, cleaned filters. I am still loosing around 3-4 ppm FC during the night. Water is clear i can see the screw heads on drains in 7' of water. 0 CC just cant pass the OCLT. I have been keeping FC at or above 16. Does it hurt to keep FC higher than recommended slam level, other than wasting bleach? During OCLT does FC levels need to be right at shock FC? Mine have been a little higher. Any suggestions? Am i missing something?
    FC- 18.5
    CC-0
    Ph- 7.5 (tested before bringing up fc)
    TA- 80
    CH-250
    CYA-30 (just re-checked was 40 when started. have added water since start)
    triptyx's Avatar
    Apr 2016
    1,438
    From what I understand, trying to keep FC higher than SLAM level causes even more sun burnoff and generally just wastes your bleach. Too much higher for an extended period of time can cause liner bleaching (not that that's a problem for you) as well.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Mar 2014
    Angleton, Tx
    91
    gotcha, ill try and keep it closer to shock level
