Thread: In-Ground, Pool-Connected Spa Bird Deterrent
    Jul 2015
    Phoenix
    72
    So, I've read lots of posts where people are trying to scare birds away from their pools using fake owls and snakes, etc.
    In my case, the in-ground, attached spa is like the water cooler at work. The lowest part of the spa (where water flows over into the pool), is where the birds hang out, drink and poop. And, of course, since it is a popular place, they poop all around the spa, too. In this 110+ degree weather, it bakes on the decking and can remove paint when removed.
    Has anyone tried handcrafting a bridge that would span the tallest parts of the spa? This would allow water to still pass under the bridge, but the bridge would be too high for a bird to sit on and drink (would be the same height as the rest of the decking around the pool).
    It would be easy to build using wood and would not be making any contact with the water. But, if it were to ever rain, I'm wondering if it would allow sap or some other unwanted thing to get into the pool(?). Plastic may also work, I'm just not sure how I'd make one from plastic.
    I can whip together a drawing if this is not making sense to anyone.
    If anyone has already made such a contraption, I'd love to see your pics and know what you made it out of.
    18K gal, 32' x 17' IG, pebble - Hayward SwimClear C5030 cartridge filter, 2HP Hayward pump, Hayward W530 leaf canister, Hayward AquaNaut 200 automatic pool cleaner, Taylor K-2006 test kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: In-Ground, Pool-Connected Spa Bird Deterrent
    if you used cedar or teak I don't think you would get any sap and if you sealed it it should last for a long time..
    Dec 2014
    Houston, Texas
    134
    Being a Florida Gator fan I made a point to ask a customer if they were as well based on 4 floating gator heads in the pool and 1 in the spa. They replied no ( were Aggie fans....) and that the gator heads keep the birds away. True story!
    Jul 2015
    Phoenix
    72
    Cedar or teak - thanks. Does anyone have a recommendation for thickness (so it will not warp heavily over time)? The piece of 1/4 plywood I have out their now is already bowing.
    Mar 2015
    South Texas
    411
    I've read good things about this bird deterrent working really well:
    Bird Scare Cat keeps birds...
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Jul 2015
    Phoenix
    72
    So, far my plywood strips are working like a champ. All around the spa is free and clear. I don't know why I didn't think of this earlier. I'm going out to buy some proper wood... then seal and paint. Thanks!!
