Still new to the Pool math calc but I got a reading of 0.19 with the numbers I provided above today. I assume as long as I am within -0.06 and + 0.06 I am ok?
Thanks, I think I have been given wrong information for the last 2 years. For the scale treatment would it require an acid bath and re-polish?
Alkalinity and algae are unrelated.
Your TA is fine where it is if that number is accurate. The PoolMath calculator is set up to account for alkalinity corrections based on other levels. Your current numbers equate to a CSI of +0.05. You'd still be in good shape dropping your TA into the 60s.
Yes. You're being pool-stored! They are trying to sell you lots of baking soda for no good reason. There is no reason to use adjusted alkalinity as a measure and, by them telling you that you need to get that up to 125ppm, that would force your total alkalinity to 170ppm. At that point, your pool would be so over saturated with aqueous carbon dioxide that your pH will rise like crazy. I doubt you'd ever get it below 7.8. With your current pool water numbers and a target value of TA at 170ppm, your CSI would be +0.52. If your pH rises to 8.0, which it almost certainly would, your CSI would go up to 0.68 and scaling would likely happen. I'm not a plaster expert, but it would not surprise me at all if all of those discolorations blooming on your pool surface is scale.
So my suggestion to you is to dump Texsun Pools, test your water yourself and follow the advice on this forum.
