Thread: Dolphin Deluxe 4 Robot Question
    Apr 2009
    Phoenix AZ
    11
    Hello....Over the weekend I just bought a Dolphin Deluxe 4 from Leslies Pool Store http://www.lesliespool.com/browse/Ho...200020/I/84315 Since this thing operates seperate from the pool pump and filter does anyone have an idea of how long I should run my automatic pool pump timer at night? Does it have to run at all? Right now it's set at 4 hours a night because I used to hook up my old Kreepy Krauly to clean the pool at night for a lower electricity rate. While she's not giving me any grief about the purchase....I'd like try to justify the new Dolphin purchase with my wife with a lower electric bill and other ways if possible!
    My Pool - 21,000 Gallon Plaster In Ground Manatee Shaped Diving Pool - Sta-Rite Dura-Glas Pump 1 1/2 hp, 3450RPM, 48Y Frame, 230/115 Volts, 60hz., 9.6/19.2 amps - 24" Jacuzzi Bros Sand Filter 60 GPM (46 Backwash)
    Apr 2009
    Phoenix AZ
    11
    Re: Dolphin Deluxe 4 Robot Question
    Is this that dumb of a question that nobody wants to answer Ha ha. I do realize the pump and filter move the water around and know that is good for the water but the robot seems to do the same thing as I see what looks like a pretty powerful jet of water being spewed out of the top of this thing. Someone lemme know when you can please. Thanks!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    It's not an easy answer. Depends on your chlorination method, debris load, heating/cooling needs and bather load among other things. I never run my pump at night, but you may need to. Trial and error is about the only way to figure out what your pool needs.
