Thread: How to find repairman for pool heater
    My 5 year old Rheem gas pool heater needs repair. I've had someone come look at it and he replaced the thermostat which had corrosion on it, but basically told me I should replace the heater. He only took the front panel off and seemed hesitant to get too deeply into it. The problem is that it lights and starts heating, but shuts off after about ten minutes. Then I have to shut down the power and restart it...and it does it all over again. Once in a while it will keep running until it gets to the set temperature. I am hesitant to call someone else and go through the cost of another round of servce calls, but I just don't believe I need to replace the heater. How do I find a knowledgeable repair person? I found the first person through Servicemaster.
    Re: How to find repairman for pool heater
    Since you didn't provide any location information, you might want to start here:
    Rheem Pool and Spa Warranty Service
    Go to find an independent contractor a the upper left and type in your zip, then look for those that do pool and spa work.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Thanks for the link! (Atlanta area, by the way)
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Call Raypak and they can help find a local service company.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
