Results 1 to 8 of 8
Thread: Just turned green
    Jun 2016
    Alton, IA
    4
    Just turned green
    Help...pool was murky cloudy yesterday and now this afternoon it's greenish. Slightly overfilled it Sunday night..I think that's what threw everything off.
    CYA was basically 0. I added 12 pounds to the skimmer this morning...unfortunately I didn't read about your sock method before that. Can't backwash for 48 hours. I added 3 gal of 10% liquid chorine and 2 gallons of 7%. FC read 8 or 9 after the whole process. (Again, wasn't sure what shock value should be exactly--I was aiming for 10)
    Just tested water again using Taylor K-2006 kit:
    FC 3 CC .3 to .5
    pH 6.3
    Alkalinity 140
    CYA still reading 0 (according to strip)
    Wondering if I should focus on raising pH before adding more liquid chlorine to shock? What should my next step be?
    20x44 vinyl liner in-ground, 40,000 gal, Pentair components: IntelliFlo VS-3050, Triton II sand filter, IntelliChlor SWG; automatic cover is on whenever not in use
    Aug 2014
    Northern IL
    4,615
    Re: Just turned green
    You can add borax and chlorine at the same time. 6.3 is a weird number for pH with a 2006. How did you get that?
    Jun 2016
    Alton, IA
    4
    Oops, meant 6.5--I did the base demand test and it took 20 drops to get back up to 7.4. I'm not sure what that means in terms of how much Borax to use. My booklet only lists how much Soda Ash to use to raise pH. I also read somewhere that the pH will come back up with time and aeration??? Is that true?
    Aug 2014
    Northern IL
    4,615
    The booklet is too confusing and not always in agreement with what we do. Most people use PoolMath instead: Pool School - PoolMath
    Aim for pH of 7.2. I would recommend borax instead of soda ash because borax will have less effect on your TA.
    Aeration is great, but it can take a longish time and your low pH is a "fix it now" issue.
    You can find borax in the laundry aisle: 20 Mule Team Borax in a box.
    Jun 2016
    Alton, IA
    4
    Alkalinity is also high--how is adding borax going to affect that?
    Aug 2014
    Northern IL
    4,615
    Each 76oz box of borax will raise your pH by 0.3 and raise your TA by 5. It is just that you pH is dangerously low and a quick fix is better than slow aerating right now, IMHO.
    Jun 2016
    Alton, IA
    4
    Thanks!
    Aug 2014
    Northern IL
    4,615
    Since you have "green", once your pH hits around 7.2, you get to SLAM. Here's how:
    Pool School - SLAM - Shock Level And Maintain
