Thread: Pump Motor Issue and Shock
    Aug 2013
    Dallas, Texas
    85
    I have something going on as my Chlorine level in the pool and began to the shock process the Monday evening, the next morning the motor was not running and it appears switched its self off.
    Ever since the pump motor has been switching it's self off after 10 / 15 mins of use so I have decided to order a replacement run capacitor and a new motor just in case.
    My question is that should I be fighting algae growth by adding Chlorine and trying to move water around or just fight the algae once the pool is up and running, it feels like a loosing battle with no pump running and I don't want to keep wasting the bleach if it keeps getting eaten up, and not sure getting it to shock level without the motor is worth it?
    any thoughts?
    17500 Gallons, IG, Plaster, DE Filter, Built 1997, No Spa, Polaris 280
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Pump Motor Issue and Shock
    Adding bleach and brushing the pool to mix it will help to kill the algae.
    Aug 2013
    Dallas, Texas
    85
    I received my new pump motor today and a capacitor - the capacitor was to big to fit my motor spacing so I decide to just replace the entire motor that comes with a capacitor.
    It took about 90 mins to rip and replace and the system has been running for past 3 hours.
    So far so good - time to slam
