Thread: Hayward eyeball and Intex Robot
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    Is there an adapter to allow one to swap out the original Intex return to a Hayward eveball and STILL be able to run the Intex Robot?
    TIA!!
    Intex 20x52 above ground pool-
    8632 gallons
    1 man 4 woman Bullfrog Hot Tub
    http://www.flickr.com/photos/pitguy3/se ... 763801706/
    ROLL TIDE!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hayward eyeball and Intex Robot
    intex uses different threads on everything so you're not able to do what you're trying, not really on purpose but it's made in china...
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    I was afraid of that... Guess I will just keep the Intex eyeball until the robot dies...
    8632 gallons
    ROLL TIDE!
    Jun 2016
    Sterling Heights
    6
    I'm actually trying to figure this out as well... I'm new here, so bare with this newbie pool language. Lol
    I THINK, haven't tried, that the piece that came with the hayward skimmer ( there was 2, 1 I used to connect to the bottom of the skimmer for the hose to connect. Threaded on 1 side, not on the other) fits into the hayward inlet afyer removing the eyeball. That does fit, I tried. So then I grabed my robot tubes and took off the dark gray part that originally would connect it to the intex inlet, pushed back the light gray screw so it moved down the tube. The tube then fits over the white smooth side of the hayward piece. I am guessing you could use a hose clamp to secure it more. These all fit together, but I haven't installed the new hayward inlet to know if it works!
    Hope you understand my description... sorry it's so vague!
    Let me know it if works!
    mulia's Avatar
    Jul 2011
    NE Ohio
    100
    Quote Originally Posted by pitguy3 View Post
    TIA!!
    figured it out...
    here's a hayward inlet outlet fitting
    [URL=http://s61.photo
    This intex adaptor screws into it
    here is the adaptor
    then, a intex hose screws onto adaptor
    [URL=http://s61.photobucket.com/user/elijah1741mulia/media/image_zpszl0jgzfg.jpeg.html]
    [/URL
    then an old intex wall fitting screwed unto the intex hose,
    then, I believe, your intex robot vac screws onto the original intex wall fitting ( hopefully, I don't own that vacuum)
    the gray adapter,intex hose,and old intex wall fitting can be left attached to your robot hose and just connected to your hayward fitting while vacuuming( you would unscrew the eyeball fitting in your hayward fitting before connecting this contraption.
    hope this helps!
    INTEX AGP 15'x 48", 4440 gals.,INTEX 2650 gph pump w/ 16" sand filter, Hayward widemouth skimmer,INTEX SWG-CS8110, 1 1/2" hard plumbed PVC, Lil' Shark vac w/ leaf canister, INTEX floating LED pool light, solar cover with polaris solar reel, Access pool steps 200600T, TF 100 test kit, "The Slime Bag" x-tra polishing 18" x 30"
