Thread: cya and slam question
    May 2016
    spring hill fl
    13
    My swg would not keep up. my cya was low so I added it to the pool and now it is at 150. was wondering about the dangers of this and I am still loosing chlorine I added shock about a week ago and was getting a reading of over 10 on total chlorine and 10 on fc. Today's test showed 4 on TC and 3 on FC. Now my water temp is almost 90 and the pool is in total sun here in florida. I did a chlorine lose test and lost 1 overnight. What is stumping me is why the swg is not keeping the chlorine lvl up (my swg is new because I thought the last on wasn't working).
    My next question is when slamming the pool how high do I keep the chlorine lvl and do I just keep adding shock to keep the lvl there?
    5400 gal intex pool
    Total Noob!
    Spring Hill, FL.
    5455 gal AG Vinyl pool
    635t Intex filter (cartridge)
    Krystal Clear 7110 SWG
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: cya and slam question
    If your CYA is 150 your minimum FC is 11. SLAM level is 60.
    How are you testing?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    domct203's Avatar
    Jun 2015
    CT
    3,589
    Quote Originally Posted by mdsmitty View Post
    5400 gal intex pool
    How are you measuring that 150ppm CYA? What was your CYA level before you raised it, and what FC target were you trying to maintain?
    What type of 'shock' did you add?
    150ppm IMHO is unmanageable, with only 5400 gallons it would be best to drain 2/3-3/4 and refill to get that CYA down to 40-50ppm.
    Whatever you do at this point, it is critical that you have accurate test measurements. How do you test your water?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    domct203's Avatar
    Jun 2015
    CT
    3,589
    I noticed that about a month ago it looked like you had an algae bloom starting, and it was recommended to SLAM the pool.
    liner feeling slimy or slick
    Did you ever complete a proper SLAM?
    Have you done a recent OCLT to rule out algae?
    swg will not keep up
    Dom
    Dom - TFP Guide
