Thread: Return line plug
    Jun 2016
    Kingwood, TX
    7
    Return line plug
    I purchased a Polaris 360 and I need to plug my return lines. It took me a few hours to be able to unscrew the threaded fitting to plug in the Polaris however I need to plug two more and it's a huge hassle. I am able to unscrew the outer eyeball fitting but unable to unscrew the threaded housing. Are there any outer fittings that I can use to plug the return versus the whole piece?
    For example: this part has the thread built in - I just need the outer part.
    Amazon.com : Threaded Pool Return Line Plug - IG Pools : Swimming Pool Maintenance Kits : Patio, Lawn Garden
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,428
    Re: Return line plug
    What kind of pool do you have? Above ground? In ground? If we knew this info. we could help you better. I have a couple of ideas depending on your pool. Could you please fill out your Signature? Go to Settings-upper right side, edit signature-middle left side. Put in pool kind and size as well as what equipment you have.
    Kim
    Jun 2016
    Kingwood, TX
    7
    updated
    Inground pool. Pentair Whisperflo 1.5hp pump, Clean and Clear 420 Filter, Polaris 360
    Jul 2012
    Tallahassee, FL
    30,428
    Okay so since it is an in ground you should have valves by your equipment. Do you know which valve goes to which item-skimmer, return, etc. I am hoping each return has it's own valve.
    Kim
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    You can often remove the fittings with a pair of needle nose pliers by spreading the tips to engage the notches inside them. There is a tool made that will remove them as well. It's a Hayward SP-1419T.
    You may be able to save yourself a lot of trouble by just rotating the eyeballs until they are about 90 degrees from normal. They will block almost all of the flow. Way easier than plugging.
    Jun 2016
    Kingwood, TX
    7
    I will try the 90 degrees from normal. I have the tool and I was not able to remove it. I hacked at it with pliers until i completely broke the plastic threads and then it came out.
