Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Cost of concrete decking per sq ft?
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    What did you pay for your concrete decking per sqft? How much did you pour? We get 4ft around the pool included...thinking we might need about 600 sq ft extra. Curious what others used and were charged so we can get an idea on our budget. TY!
    IG Vinyl Mountain Pond 22x36/ Depth: 3'4"-6'6"/ About 19,000 Gallons/ Pentair/ Clean&Clear Plus420/ Intellichlor IC40/
    Easy Touch/ Intellabrite 5G LED Color-Changing Light/ DeckJetsII/ S.R.Smith slide
    Aug 2015
    PA
    74
    Re: Cost of concrete decking per sq ft?
    I had 3 quotes from my recent project. In the end, we decided to go with pavers. I would imagine pricing can be region specific.
    All were stamped concrete, around 850/sqft. We never got into the colors or patterns. These were all quoted direct from the PBs. Might get a better deal going direct to an installer.
    $11.31/sqft
    $9.54/sqft
    $12/sqft
    New salt diving pool started in February 2016. Approximately 42x20 kidney shape. 100 sq/ft tanning shelf. White Plaster. 2 Pentair 5g Color LEDs and 1 Color Globrite LED. All Pentair equipment. DE filter. Kreepy Krauly 820 robotic cleaner. EZ touch wireless system. 860 sq/ft Techo-Bloc paver patio with matching fire-pit.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    It's going to vary by your location a bit, but the general guideline for concrete is $5-9 per square foot around here, depending on finishing options, layout and grade/sloping.
    Isolated Spa - 345 Gallons
    May 2014
    San Jose, CA
    153
    15$ sqft
    stamped was 17$ sqft
    10% off for jobs over 1000sqft
    Our Build 2016 14.5' x 26' IG Pebble, 14.5K Gal. 3.5' - 6.5' deep, 5 returns, 2 Skimmers, Hayward VS pump, Hayward 525 Cartridge Filter, Hayward E-Command 4, Heliocol Solar, Hayward LED Light, Paramount Ultraviolet, Polaris 280, AquaRite Pro, T-CELL-15, Sense and Dispense (HL-CHEM), Ph Dispense System (AQL-CHEM3) , Taylor K-2006 with SpeedStir
    Jun 2011
    Carlsbad, NM
    172
    I had 1200 sf of dyed and stamped done for $8.50/sf.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    If you're going with dyed and stamped ask to see past examples. Our neighbors decking looks fairly awful (color not well applied) but we saw a different deck last week that was gorgeous. Levels of skill vary.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    We are going with basic brushed concrete. Had considered pavers too... We are doing a mountain pond shape so wasn't sure if we'd need extra concrete due to the shape. Seems like the PB is charging more than if we went direct to the concrete contractors. I guess that would be the norm though.
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    241
    Hi Crickets, We were debating between Kool Deck and brushed concrete. Brushed is about 40% less than Kool Deck and probably much less than pavers too. Concrete here in Phoenix is probably the cheapest in the country and runs $5-9sf...probably higher in KY and other more northern areas.
    14x28 IG Rounded Rectangle, 6" aqua tile, White plaster, Gray Acrylic deck, 4' Baja Step (18"), aerator jets, 3-step InterFab SS Ladder, Pentair Intelliflo VS Pump, Pentair TR100C Sand Filter, Stenner Econ E10T2A (chlorine), K-2006, Zodiac Baracuda G3 pool cleaner
    Quote Originally Posted by Crickets View Post
    That's the general idea. He takes added responsibility for it so he takes a cut. You can try to save money negotiating it separately but if anything goes south you'll have to deal with teh finger-pointing between the sub and the general, with each denying responsibility.
    Yes you pay more when you hire a general contractor, but you also have a single point of contact and a clear pecking order.
    Geebot
    Chicago, IL
    Jul 2015
    Douglasville, GA
    35
    In Georgia, my contract included 1500 sq ft stamped. Anything over was supposed to be $8.50 sq ft. Ended up upgrading to pavers for $1 more a sq ft. Ended up with 2500 sq ft . We also had an option for plain concrete.
    So, per foot for me:
    concrete - $6.80
    stamped - $8.50
    pavers - $9.50
    Done! - 105' perimeter, 20x40 gunite pool; Pentair equipment; tanning ledge with 3 LED bubblers; 2 color LEDs in pool; 2500 sq ft Belgard Lafit Rustic Slab; Blue Surf Pebblesheen color; 4'x12' Waterfall;
    Jun 2016
    Central Valley, CA
    31
    Those are some lightly high prices. We just had 11 yards of flat work poured Monday on top of the 9 yards of pool decking included in my bid poured last Friday. We used the same concrete guy for both, with my PB knowledge. Through the PB I was paying $5 sq ft for plain grey brushed flat work. Through the concrete guy directly (un-licensed as he technically works under the PB license) we paid $3.50sq ft.
    Both the PB or direct to concrete crew, $1+ stamped and $1+ colored.
    Jul 2015
    Landale, PA
    107
    Stamped was $12 sq foot. I think this is very region specific however.
    To be built Spring 2016. 750 sq foot gunite free form. Raised spa with spillover and dedicated pump, 16 foot fiberglass slide built into hill with bolder steps, approx 1,000 sq foot stamped concrete deck, Pentair VS+SVRS pump, Sta-Rite 400,000 btu gas heater, Sta-Rite System 3 cartridge filter, Pentair Intellichlor IC60 SWG, Pentair Intellichem, Pentair Easytouch, Rapids 4WD pool cleaner, 2 LED Intellibrite lights.
    Nectarologist's Avatar
    Apr 2015
    New York
    427
    Wow clubhouse. I was quoted $6/sq back in 2001. I was looking at 10-11 this year. I wound up going with pavers for $15/sq. It's funny how prices vary from region to region. To answer you Crickets I was looking at $10-$11 this year (just outside NYC). Ask about pavers. As you can see by dldave's reply it may not be much more (and they don't crack like concrete).
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    Jun 2016
    Central Valley, CA
    31
    Quote Originally Posted by Nectarologist View Post
    After I found this guy courtesy of my PB all my neighbors took note. The concrete guy has now already done 2 other small jobs for my neighbors and several others are planning to use him. We are a brand new neighborhood with lots of concrete work needed.
    Personally I don't know how this guy is making money at $3.50, mud alone is $95 yard or $1.35 a sq ft for 4" flat work. There are seven guys on the crew and they are efficient, the 11 yards they poured Monday was done start to finish in 6 hours. They started setting forms at 7am, pouring by 9am gone by 1pm. Heard they went and poured another truck (9 yards) in the afternoon. So far everything is still curing, but the work looks great. Time will tell if the work holds up -- but the PB has been using this crew for 3 years with no issues.
    Sep 2015
    Austin, TX
    144
    In Austin, TX, I saw $5.50-6.50... most were around $6.50. Kool-Cote tried to give me a starting price of something crazy like $5 per sq ft (on top of the cost of the concrete I paid). They quickly came down to $1.85 (supposedly builder price). Note that kool cote is cheaper on new concrete since they don't have to grind it to make it level.
    We interviewed like 5 patio guys. Don't recommend the craigslist approach. Ultimately, we found two great ways of identifying good concrete people: 1) recommended by our other contractors that we used, 2) does the concrete work for x, y, and z major builders. The guy we ultimately went with is well known in Austin, is used by the top builders, and has been in the business 20+ years (he was like 50 so he just oversaw the work).
    In terms of amount of concrete, I recommend doing as much as you can. At the urging of TFP, we doubled our initial amount and are glad we did. I wouldn't want any more than we did because I still want to retain room for soccer with the kids, but I'm glad we upped it (800 sq ft vs ~400).
    Construction underway.
    33x23 freeform 16k gallon IG pool, pebblesheen, SWG in Austin, TX
    Pentair 3HP VS pump, Hayward 30" sand filter
    Build thread: New Austin, TX Owner Build
    TortugaCat's Avatar
    May 2016
    Boston, MA
    82
    We were quoted $18/sf for pavers. I would like to do brushed concrete, but all the PBs we spoke with in MA seem against it unless it's stamped. Not sure why...
    Pool + Spa in MA -- 40' x 16' gunite pool, 8' x 8' spa with spillover. PebbleSheen Ocean Blue. Vibrance Glass Nero 2" x 2" tile. SWG, Paramount in-floor cleaning system, 400 BTU Sta-Rite LP Gas Heater, ACT1500 Heat Pump, S7M120 Sta-Rite Modular Media Filter, IntelliPro XF 3.0 HP Pump, SuperMAX VS 2.2 HP Pump, AquaLink automation. LP gas firepit. 1700 sf stamped concrete patio.
    Apr 2013
    Sacramento, CA
    2,769
    Clubhouse -- you got $3.50 a square in California, where Alturas? Where in the valley did you get that? You can't pay a crew and taxes and insurance for that.
    So Sacramento is 7 to 22 a foot depending on what you want. For example is it stamped, is the color throughout or only on the surface. What is the prep work. Rebar, wire or nothing?
    And its usually less expensive to contract it outside the pool builder.
    Jun 2016
    Central Valley, CA
    31
    Small town just south of Fresno
    Be sure to note that the concrete crew is not an independent licensed & bonded contractor. They work through the PB under his license and get paid through his payrol. That portion of the job was $4 sq ft and included in my pool bid.
    The side work was paid directly to the crew in cash, with the pool builders knowledge but was not involved in the transaction. I have no idea how the money was shared and I doubt seriously any insurance or taxes were set aside by the guys.
    By the way construction labor typically is paid $12-$15 hour around here. This certainly not the Bay Area or LA.
    Sacramento is certainly higher, but my Brother in Law is in Eldorado Hills and last fall had about a 500 sq ft patio extension poured for $5. Agian it was side work for a crew paid in cash and it was grey/brushed, not stamped and/or colored. There are plenty of people willing to do concrete for far less than $7-$22.
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    $6.50/sqft for the concrete, $5.50/sqft for the stamped overlay and coloring (effectively a kool deck application).
    Worth noting that stamped concrete and stamped overlay are a little different. Stamped concrete is where the concrete itself is stamped and colored whilst still curing and gas to be done before it sets. Stamped overlay is applied on top of the concrete in a separate application.
    38'x24' freeform IG gunite, 26k gallons, 3.5' - 7'
    8t Moss rock waterfall with gunite slide
    SWCG, 2 x 2.7hp Hayward Tristar pumps, booster pump, 425 sqft cartridge, 400,000 BTU heater, Polaris Black Max 280, ProLogic PS8 & Aquapod
  20. Back To Top    #20
    Feb 2015
    Davis, CA
    97
    When I had my pool done, I was quoted $12/sqft. This did not included any rebar which would have cost another $1/sqft for an 24x24 grid. I installed my own rebar in 18x18 for about 1/4 of the price.
    Pool Remodeled June 2015. 18K Gallon IG kidney shaped. Pebble Tec (Tahoe Blue) finish. Jandy ePump 2HP. Hayward SwimClear C2025 filter. Hayward SWG. Jandy iAqualink RS6 automation. 6 Deck Jets. Pool Remodel Link Future: Acid automation. Chlorine automation for winter. Solar panels.
