Thread: Solar actuator gone bad.
    Feb 2011
    Petaluma, Ca
    665
    The motorized valve that turns my solar on and off developed a leak in the stem, I guess the o-ring goes bad over time. I wasnt really worried because it was a slow drip, over the course of a year it increased to a more rapid drip. Other than being annoying I wasnt worried much but then on Monday the valve stopped working. Today when I took it apart I found that the water had mad it way up into the motor and its now shot. I wish I replaced the oring before this occured.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    38,251
    Re: Solar actuator gone bad.
    Uh Oh .. mine has been leaking a lot recently too. Guess I should do something about it while it is just seals and not the entire actuator.
    May 2015
    Land O Lakes, FL
    527
    Look for Intermatic Actuator on Amazon. It is less than $100
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
