Results 1 to 10 of 10
Thread: pump basket air - should there be any?
    Jul 2013
    Cedar Rapids, IA
    82
    Hello!
    I was having trouble with priming my vacuum hose and was browsing around for possible causes, and one mentioned was a suction side air leak.
    Question: When my pump is in normal operation (no vacuum attached), looking through the lid the basket is completely full except for a small air pocket at the top, between 1/3 and 1/2 the diameter of the lid. Does that indicate an air leak, or is that normal?
    Thanks in advance for your help!
    24,300 gallons, IG vinyl, Hayward Pro Series S244T sand filter, 3ft to 9ft deep
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: pump basket air - should there be any?
    It's most likely normal. An easy way to 'prime' the vacuum hose is to hold it over a return. Once all the bubbles stop it's pretty near full.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2013
    Cedar Rapids, IA
    82
    Yeah, I did that. I just wanted to rule out the leak issue. That's a relief at least that the bubble at the top is fairly normal.
    Um, I just realized my vac head is missing one of the little knob things, there's one on each side. Not sure what those are for, would that affect it? (sorry if this is a dumb question...)
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Sorry, will need a picture to help with that one.
    Jul 2013
    Cedar Rapids, IA
    82
    Quote Originally Posted by pabeader View Post
    Like this, one of the two blue knobs is missing:
    poolmaster-27400-classic-air-vinyl-liner-vacuum-head-13-inch-076bf3620732f13dbe982ca488981c93.jpg
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    If the whole piece is missing you are going to lose suction through that hole.
    Jul 2013
    Cedar Rapids, IA
    82
    AHHHHH, I wish I would have thought of that sooner.
    Alright, I will get a vacuum head then. Thanks for fielding my questions!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    You could try putting strong tape. like Gorilla tape, on top covering the four little holes.
    The only purpose for those is to help relieve some of the vacuum. Not sure why you would want to do that, though.
    Jul 2013
    Cedar Rapids, IA
    82
    Alright, thanks again!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    You are very welcome! Glad to be of service.
