Thread: hard plumb and LIQUIDATOR Install (HELP NEEDED)
    May 2014
    Nevada, TX
    238
    Ok, so today was supposed to be the day we were going to hard plum our pool and install the liquidator.....
    So my Dad and my cousin went to home depot to buy the supplies while I went to work. I come home to find out they didn't buy anything. They said they could not find any connections/fittings to fit the skimmer and pump, or going from the filter back to the pool.
    I don't have anything special....its a Hayward set up so I would assume the size and fittings we need would be pretty typical would it not?
    Or, is it possible they just didn't know what they were looking for? LOL
    HELP!
    Also, if you have installed a liquidator, I would like to see some pictures if you have them!
    Steve
    27'x54" Sharkline Venture
    Hayward X-Stream Full-Flo 150 sq. ft. Cartridge Filter
    Matrix 1.5HP Dual Speed Pump
    Hayward Aqua Critter Automatic Above Ground Swimming Pool Vacuum Cleaner AR500Y
    TF-100 test kit
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Re: hard plumb and LIQUIDATOR Install (HELP NEEDED)
    Hayward is 1 1/2 inch threaded fittings coming from my filter to the pool, I install a LQ earlier this year but not able to take pics right now. I followed the instructions, watched the HASA video on You Tube. Install was pretty straight forward and easy. I read allot of Threads on this site about installing the LQ, Get some good quality Teflon tape or paste and take apart and re-seal all fittings that come with the LQ, My LQ is in full sun so I made box out of insulation foam sheets to protect the chlorine
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    May 2014
    Nevada, TX
    238
    Ok, i found an old threat that said a typical install will require at least 6:
    "1 1/2" male adapters (male threaded on one side and female slip on the other) to screw into the bottom of the skimmer, outside of the return fitting, 3 filter ports, 2 pump ports. Enough pipe and elbows to make necessary turns. You can use all 90's, or 45's where possible for less drag. Of course you will need the proper cement and primer. You will also need a method to seal the threaded fittings (teflon tape, dope, thread sealer....that is a whole 'nother discussion)."
    So, I am looking at home depot, does this like right to you?
    Charlotte Pipe 1-1/2 in. PVC Sch. 40 MPT x S Male Adapter-PVC021091400HD - The Home Depot
    or no?
    Also, for the union ball joints, I am looking at these on Amazon:
    Amazon.com : Hayward QTA1015CSEG 1-1/2-Inch Gray QTA Series True Union PVC Compact Ball Valve with EPDM O-Rings : Swimming Pool Digital Readers : Patio, Lawn Garden
    Does this look right?
    Thank you!
    Steve
    so the male adapter looks awful shallow to me. If this isn't right, please direct me to what would be.
    Thank you,
    Steve
    TF-100 test kit
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Subscribing to your thread because I am in the same boat.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    May 2014
    Nevada, TX
    238
    Has no one else had this issue and figured it out? I'm stuck here...
    TF-100 test kit
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    222
    There is a difference in PVC pipe, for a pool pump you need both pipe and fittings rated for use as water line.
    If you look below in the product overview below your threaded fitting, it says "intended for pressure use" so you are good to go.
    Drain systems are often plumbed using foamcore pipe, it will sometimes be stamped as DWV and is not rated to handle pressure, this is especially true for larger diameter piping. The fittings make more long sweeping bends and the fittings will have more shallow glue surfaces.
    PVC rated for use in water line is much stronger and will have a pressure rating stamped right on the pipe. The fittings have deeper sockets for the glue joint and a 90 degree fitting will be more squared off instead of sweeping bend.
    The gray unions and ball valves are the good stuff, they will work fine and last for years.
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
