Results 1 to 7 of 7
Thread: Essential Home Bleach at Kmart
    Nov 2015
    Lawrence, KS
    69
    I saw this was $1.99 a gallon but it does not state the chlorine %. Anyone use this or have any background on the available chlorine?
    Constructed in Spring 2016, 20x40 inground vinyl liner pool; depths from 3.5 to 6.5 feet; 26,000 gallons, Pentair sand filter, Pentair two-speed Whisperflo pump, In-line chlorinator (don't use it though), 125,000 BTU Pentair Heat Pump, Coverstar Automatic Cover, TF-100 Test kit, fill pool with city water.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Essential Home Bleach at Kmart
    The general rule is: if a concentration is not listed, assume it is 5% or less. Many times they are 3%. I never buy bleach w/o a concentration known.
    Isolated Spa - 345 Gallons
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    I'd stay away if it doesn't list the % on the bottle.
    Usually cheap bleach with no label is <6%
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    379
    Quote Originally Posted by dkite22 View Post
    I just looked it up online and it's not even listed in the product specifications.
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence T-5 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
    Nov 2015
    Lawrence, KS
    69
    thanks for the info everyone. I will stay away!
    Mar 2016
    NE OK
    18
    I'm looking to stock up on liquid chlorine. The sticky up top is from last year. Is there a thread with current location/prices?
    EDIT: FOUND IT
    http://www.troublefreepool.com/threa...-bleach-prices
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Be careful on "stocking" up. It loses strength over time, better to get fresh bleach every couple of weeks or so, at least. Otherwise, keep it in a cool dark place.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
