Results 1 to 7 of 7
Thread: Preparing pool for the first time help!
    Jun 2016
    Warrenton, VA
    6
    Question Preparing pool for the first time help!
    Hi everyone!
    I have a new ag pool that has just been set up two days ago. I have NO chemicals or testing kit to start with and am trying to stay on the lower end of our budget.
    Where exactly does one start when obviously so unprepared?
    Coleman 18' x 48'' 6,000 gal. round AG pool,FlowClear Filter Pump 90401e (came with pool), installed and filled 06/27/2016 with city water. Taylor Technologies K-2005 - DPD Complete Chlorine Kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Preparing pool for the first time help!
    A proper test kit is the most important tool for maintaining your pool. It cannot be done without it. Check out the recommended test kits in Pool School. Pool School - Test Kits Compared The TF-100 is the best $70 you'll ever spend on your pool (see link in my signature).
    You'll need cyanuric acid (aka stablizer or CYA). You'll need muriatic acid to lower pH. You'll need bleach to sanitize the pool.
    Most importantly, spend some time in Pool School, starting with ABCs of Pool Water Chemistry.
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    This another good place to read
    TFPC for Beginners
    Jun 2016
    Warrenton, VA
    6
    Thank you!
    Currently we have:
    Chemicals
    10% Pool Chlorine ("bleach")
    clorox ph down
    baking soda
    borax
    clorox stabilizer
    Test Kit
    I have been using the pool calculator to help me figure out how much of what to add.
    Feb 2014
    Central Minnesota
    5,080
    If you add a FAS-DPD chlorine test, you'll essentially have a K-2006 kit, which as all the needed test. TFTestkits.net
    You need this test to accurately test for FC and CC up to 50 ppm, which is required any time you need to deal with algae.
    Jun 2016
    Warrenton, VA
    6
    I'll get that as soon as possible. I have been in the hospital with gallstones and acute pancreatitis for a week and when I got home the pool was turning yellow/green!! I added chlorine right away, and that was the only thing out of whack according to my current test kit.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Chlorine is a good start.. thatll help keep the algae down. Post a full set of results when you can and we'll help you get it under control
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
