Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Aqualogic System Issue - Help
    Jun 2016
    Montreal
    18
    Hi everyone,
    New to this superb forum and my first post requesting some help.
    I have an in-ground salt pool which is managed with the Aqualogic system. I also have the wireless remote in the house. I have attached two pictures as reference.
    What is happening is without any warning nor reason I can see.. the power to the pump gets stopped.
    On the closeup picture I have attached. The moment you click on the Filter button it lights up yellow and sends power to the pump which does its thing. I wake up in the morning and there is a "no flow" warning. I head outside.. the main panel is on (digital screen is lit up). However, the filter light is not lit up. Its as if someone went and pushed the button.
    Unit is 7-8 years old and this bug is driving me mad. Because if I am away for a few days, there is a good chance that system stops working and pool will not be filtered.
    There were no power surges, even small ones as I have very sensitive UPS systems at homes for several servers.
    Any ideas would be most welcome.
    Rgds, Shawn
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Aqualogic System Issue - Help
    Is the timer, under "Timers" Menu set to a proper range?
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jun 2016
    Montreal
    18
    Hi Mikemass,
    Thank you for quick reply. Didnt even know I had a "Timers".
    Once I find it (this will be a fun search). How do I set the range so it runs 24/7/365 ?.
    Regards, Shawn
    38,251
    Push the Menu button until it says Timers, then scroll right to see what timers are set. If there is a time on/off time set, that will override you manually turning on the pump and turn it off at the normal time.
    Why are you trying to run 24/7? That is a significant waste of power and money (unless you are SLAMing)
    If you want to do that, just select the OFF time and change it to be the same as the ON time (and the timer will be deactivated)
    All the manuals are available on the Hayward website.
    Jun 2016
    Montreal
    18
    Hi,
    I have always run my pool 24/7.. And just last week I got a beautiful variable speed pump so running it at 1400rpm isnt a huge issue as far as electrical consumption is concerned.
    Also, unless I am mistaken.. If I put a timer on and it cuts power to the pump.. Unlike my old single speed pump, once the power comes back.. the pump turns on with its lights & clock.. but you have to physically push a button 1,2 or 3 and choose a speed setting to get it to start pumping again.
    Rgds, Shawn
    38,251
    Even at low speed, you could cut your power consumption by over 50% by not running so much. See: Determine Pump Run Time
    What pump did you get? Some integrate much better into the automation than others.
    Please add your pool details to your signature as described HERE as it will help us help you.
    Jun 2016
    Montreal
    18
    I'm at office now. Will post full pix when I get home.
    There is a plug on side of the pump which I was assured by store is supposed to be hooked into the main panel. I frankly am no engineer and the thought of doing this scared me to death.
    Assuming its an easy plug in.. What is the benefit of plugging it into the main panel ?
    Many thanks for taking the time.
    Rgds, Shawn
    38,251
    I think it is just like a telephone cable between the pump and automation. If you plug it in, then the automation has full control over the pump and you will never have to push any buttons on the pump. Which then obviously lets you run the pump less and save $, which is the whole point of you getting a VS pump.
    Jun 2016
    Montreal
    18
    I suspect you are right. I'll just check in the store if my 8 year old system can handle the wire or it has to be the newer versions.
    38,251
    OK ... although we generally do not trust pool store information for just about anything
    Jun 2016
    Montreal
    18
    Oh but he told me he was "Certified Pool Technician". Certainly he can be trusted
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Quote Originally Posted by israguard View Post
    Hi Mikemass,
    Regards, Shawn
    I can't attach a large PDF on this site apparantly. So go to this link:
    Manuals | Resources - Hayward Pool Products
    Click on the FIFTH one down under:
    Automation: In Ground That is the AQL-P-4 Installation
    That is your system.
    It can be a little confusing and intimidating at first. But once you get used to scrolling though the menu and the many sub menus within, you will get it.
    Jun 2016
    Montreal
    18
    You rock Mikemass.. A big thank you.
    Jun 2016
    Montreal
    18
    Hi Guys,
    Well, you were right on the money with the timers. There was a timer set from 12:15-12:00... Clearly I had gone in there and at some point in error pushed an arrow up.. I brought it back to off as per pic. Let's assume for now I want it to run 24/7.
    Also attached are two pictures of the new pump I got.
    I will go back to store to see if it can be hooked up to my system.
    Thank you all again.
    Regards, Shawn
    Jun 2016
    Montreal
    18
    Sorry.. I'm back
    I sniffed around with the settings on the Aqualogic.. It will control a 1 speed or 2 speed motor only. No option for variable speed motor.
    would you guys spend the $ on changing the box so it would control a variable speed motor?.
    Rgds, Shawn
    38,251
    Your VS pump might allow you to control it like a 2 speed motor using 2 relays.
    Jun 2016
    Montreal
    18
    Thanks for quick response. Using relays is a bit above my iq level..
    Assuming it's not an option.. Would you leave as is or change/upgrade panel?.
    Tks
    38,251
    How did you confirm your panel can not use a VS pump?
    Jun 2016
    Montreal
    18
    I went into the configuration. Unlocked it and when you get to the motor/pump.. You can choose from two choices only 1 or 2 speed only. It's an 8 year old unit as well.
  20. Back To Top    #20
    Here is the manual for the pump.
    http://www.pentairpool.com/pdfs/SuperFloVS1.5OM.pdf
    The motor is made by KINETEK ADVANCED AC SOLUTIONS.
    To connect in the automation with relays, you need the External Control Wiring Kit (Pentair P/N 353129Z). This will connect to the plug on the side of the motor and then you would use the relays in the automation box to control the speeds.
    Basically, you would wire power directly to the motor and not from the relay. Then you would plug the wiring kit plug into the side of the motor and then connect the wires into the relays as shown in the manual.
    Each speed requires a relay. I would suggest using relay 1 and 2 for two speed control. Basically, you’re treating the pump as a two speed pump but where you can set the two speeds to whatever you want.
    Support the site
