Results 1 to 7 of 7
Thread: hayward sand filter parts
    Jul 2013
    Cedar Rapids, IA
    82
    Hello,
    I have a Hayward S244T sand filter. It has a little drip around the locking brace so I want to replace the oring and see if that fixes it. I also need to replace the pressure gauge as it is stuck at 0. I cannot find a manual to save my life, so I just wanted to make sure, are these the right parts?
    https://www.amazon.com/Hayward-SX200...d+filter+oring
    https://www.amazon.com/Hayward-ECX27...pressure+gauge
    Thank you in advance!
    24,300 gallons, IG vinyl, Hayward Pro Series S244T sand filter, 3ft to 9ft deep
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: hayward sand filter parts
    Thats it. Pressure gages are mostly universal. The sell glycerin filled ones recomended here from
    TFtestkits.net
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jul 2013
    Cedar Rapids, IA
    82
    Well, heck, I'll support the TFTestKits site then, thanks for the tip!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    I have that sand filter too and a leak just like you have.
    Turns out it wasn't the o-ring but the multiport valve mounted to it
    had a small crack. You might check for water seeping out of the multiport
    unless you found it only below the collar.
    The glycerin gauge works great on that filter (I got one last fall) I'd suggest
    the rear mount gauge so it;s easier to read.
    Dolphin E10 Cleaning Robot.
    Jul 2013
    Cedar Rapids, IA
    82
    Quote Originally Posted by borjis View Post
    I'll have to check on the multiport. Already got the oring ordered, but doesn't hurt to have it just in case. Thanks for the tip.
    If I do replace the oring, can I just use Jack's lube on it?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I use jacks lube every time I take unions or filter apart. A few times on pump lid also
    Jul 2013
    Cedar Rapids, IA
    82
    Quote Originally Posted by banditig View Post
    Great, thanks! (and thanks for the reminder on the unions, I would have forgotten that...)
