Thread: New AG saltwater pool setup questions...
    Jun 2016
    Siloam Springs, AR
    3
    Hello all! I'm a noob, please bear with me.
    Pool is filled (for the first time), sand filter running, salt added and dissolved for 24 hours, salt generator running for 2nd 8 hour go. Have not added cya yet, should I add it now? Pool is crystal clear!
    Tested 7am today
    Fc=1
    Tc= 2
    Cc= 1
    Ph= 8
    Ta= 8
    Ch= 150
    Cya= 0
    I'm assuming add cya now so I slow chlorine loss?
    Going to add some chlorine bleach to bring the levels up. Do I let that run through the system and expect the pH to come back, or should I had some muriatic acid as well?
    Thats where I sit, will test later today. Any suggestions are appreciated.
    6400 gallon Coleman 18' x 48" power steel frame (AG)
    Intex Krystal clear sand filter pump 2800GPH
    Intex Krystal clear saltwater cg-28667
    Hayward sp109lx dyna skim
    Taylor k-2005 test kit
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: New AG saltwater pool setup questions...
    Suggestions embedded in bold below:
    Quote Originally Posted by Cotton McKnight View Post
    Have not added cya yet, should I add it now? Yes
    Tested 7am today
    Fc=1
    Tc= 2
    Cc= 1 (WHY Do you have CC's already in a newly filled pool? Address this)
    Ph= 8 add Acid
    Ta= 8 Think you mean 80
    Ch= 150
    Cya= 0 See above
    I'm assuming add cya now so I slow chlorine loss? YES Again
    Going to add some chlorine bleach to bring the levels up. Yes. Do this ASAP before you even respond to me. Do I let that run through the system and expect the pH to come back, (One doesn't affect the other) or should I had some muriatic acid as well? Yes, add MA
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    It is possible that the water district uses chloramines in the water sanitation process which would register as CC for a couple of days.
    Yes to CYA
    Yes to bleach
    Yes to acid
    Jun 2016
    Siloam Springs, AR
    3
    Fc=3 I want this at 4, so I'll need more bleach added .
    Tc=3
    Cc=0
    Ph=7.4 lower than I'd like
    Ta=110 add baking soda?
    Ch=140
    Cya=30 add more
    Anything I'm missing?
    DFW, TX
    24,502
    No baking soda! That raises TA. No need to raise that TA, you want it 60-80 eventually. 7.4 ph is fine.
    Your homework is to memorize this page.
    Yes, raise CYA to 80. Nice work so far!
    After you memorize the other page read this
    Pool School - Water Balance for SWGs
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Tc=3
    Cc=0
    Ch=140
    Cya=30 add more
    If anything you want to lower your TA. I wouldn't raise it anymore. 110 is within range by conventional industry standards, which is 80-120. (TFP is anywhere between 50 - 90+ depending on pool surface and method of chlorination)...
    BUT.... You fall into the Salt Water/Vinyl category. Vinyl not so much a factor, but with a Salt System, I believe you will do better with a lower TA. How much lower? That is up to you to experiment. I think 80 is a decent starting point and go lower if needed based on the behavior of your rate of pH bounce.
    Note on "Fc=3 I want this at 4, so I'll need more bleach added ." :
    You understand that Chlorine is a consumable item in our pools? This is not a one time target to achieve and you are all set. Sorry if I am being ultra-basic with this info, but I wanted to make it clear, because based on your posts I wasn't sure if you are aware of that. You can certainly use bleach to bump that number up quickly. But it gets used up. In order to maintain your target level you need to experiment with your SWG %'age output and run times to see what the ideal combination is for your pool to maintain your target.
