Thread: Flagstone Border Decay / Chipping
    Mar 2014
    Orlando, FL
    35
    Hi All,
    I have a pebbletec pool, with what I believe is a flagstone border at the top edge. It appears as if the flagstone is chipping off and decaying -- I even found a quarter size chip of it in my pool vacuum.
    I'm going to assume this has to do something with CH as my pH is usually around 7.6 sometime as high as 7.8. CH is around 200.
    Can someone confirm my theory? I plan on raising my CH to around 250.
    SWG Pool, 13,500 Gallons.
    15k gal, Pebbltec. Built in 2004. 2 HP Pump, Cartridge Filter, Hayward SWG, Hayward Navigator Cleaner, TF-100 / Orlando, Florida
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Flagstone Border Decay / Chipping
    No, the CH is not impacting the flagstone. Although, the CH is too low for your plaster/pebble. It really needs to be about 350 ppm.
    Flagstone is a natural stone and has large amounts of variations in its make up, strength and how it deteriorates. Some flake off large pieces, some flake off paper thin pieces, some pits and some doesn't deteriorate at all. We have a lot of flagstone around our pool and on paths in the yard and we have all different variations. It is probably best to have the most deteriorating pieces replaced.
    More here on your water balance, Pool School - Water Balance for SWGs
