Results 1 to 11 of 11
Thread: Opened pool up and now running into problems with water balance
    Oct 2015
    Tarn, France
    8
    Hi,
    I bought a sliding pool enclosure last summer and the pool was covered from mid October until mid May. On opening in May the water was clear and at least 8C higher than previous years, but the walls and basin were covered in green algae. When I started the pool the readings were :
    FCL=0.5, CC=1.66, PH=7, TA=101, CH=102 and CYA=45 and then things started going wrong.
    I installed new grids in my DE filter and loaded it up with 4.8 lbs of DE, then I started cleaning and shocking the pool with Sodium dichloroisocyanurate dihydrate tabs , the same as I have been doing for the last five years. After quite a few filter strip downs to clean the grids I noticed that there was a problem with the filter - the grids didn't seem to be coating evenly and there were large areas where the DE was clumped and the pool had turned into a cloudy blue mess. After chatting to other TFP forum members I came to the conclusion that the DE was to blame so I bought a different brand and within 48 hours the pool cleared. After another week of trying to get the water balanced by old shock techniques I decided to switch to the TFP Slamming technique. Now I have come to the conclusion that I do not understand what is happening with the pool chemistry and need the help and advice of the TFP experts. I will attach a list of the readings taken over the last 10 days courtesy of Jesse's excellent pool testing log V3.0.
    Attached Files Attached Files
    26K US Galls IG concrete/block construct with 2 part epoxy paint coating. Pentair Ultraflow plus 1.5 hp, Nautilus NS 48 DE Filter. Abrisud motorised pool enclosure, La Motte Color Pro 7
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Opened pool up and now running into problems with water balance
    Most folks, including myself, probably would rather not open a .zip file from an unknown source. Can you post your most recent test readings? What test kit are you using?
    Isolated Spa - 345 Gallons
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Quote Originally Posted by JVTrain View Post
    Most folks, including myself probably would rather not open a .zip file from an unknown source. . .
    x2 . . .
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
    Oct 2015
    Tarn, France
    8
    Sorry I was trying to get the file to an acceptable size for uploading and forgot that a zip file would be unwelcome. I have now scanned the results. I am using a La Motte Color Q Pro7
    Jun 2014
    Houston, Texas
    475
    I like your system. I am using a book. Is that a program you bought or something you just created?
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    Oct 2015
    Tarn, France
    8
    Quote Originally Posted by DMS2014 View Post
    No I didn't buy it I found it on TFP search for "Jesse's Graphical Pool Testing Log"
    He has obviously put a lot of effort into generating this excel spreadsheet and it works very well.
    Feb 2014
    Central Minnesota
    5,080
    General observation on your testing:
    As you can see your CYA is steadily rising with the use of dichlor (or are they trichlor?) tablets.
    Your FC is also routinely below TFP recommended levels for your CYA level. Pool School - Chlorine / CYA Chart
    Your pool needs a SLAM. See link in signature. Do you have a source for liquid chlorine (bleach) available?
    Oct 2015
    Tarn, France
    8
    The tabs were dichlor. I had to use them as I ran out of bleach.
    I believe I have slammed the pool three times as shown on the chart.
    So far I have used 130 litres of 9.6% bleach but perhaps I am doing it wrong. The morning after slamming I always seem to be at a very low FC.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    SLAMming is not a one time event. Read this a couple of times. Pool School - SLAM - Shock Level And Maintain
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    cpeterson70's Avatar
    Sep 2015
    Carrollton/TX
    121
    Free form, according to plan - 33' X 17' (3 1/2' - 6' deep) plaster pool (approx 13,700 gallons pool, 700 gallons spa). Chlorinated. Jandy equipment, DE filter, free form elevated spa, 2 skimmers, 5 returns, tanning ledge, 8 ft weeping wall of Oklahoma/Moss boulders (double as retaining wall), Oklahoma flagstone coping. TF-100 kit and speed stirrer. Full sun 9-4:30.
    Oct 2015
    Tarn, France
    8
    Quote Originally Posted by lumpypossum View Post
    So I have read up again on the Slamming instructions and last night I had the following measurements:
    6/30/16 10pm 0 (FC), 0.3 (CC), 7.4 (PH), 126 (ALC), 85 (CYA) so I added 34L Bleach at 22:15pm looking for Slam Fcl of 33
    The readings this morning 7/1/16 9:15am are 8.8 (FC), 0.5 (CC), 74 (CYA) so to maintain the Slam I added 20.85L Bleach at 09:30 looking for slam Fcl of 29.
    Should I be checking more frequently to maintain the Slam at the highest level? I will obviously have to improvise with the La Motte tester as it's FC range is only up to 10ppm but I am sure I have read that this is possible.
