Results 1 to 7 of 7
Thread: Asking About Levels
    Apr 2016
    Houston, TX
    23
    Asking About Levels
    I have a 15000 Gallon inground plaster pool that I am trying to use the BBB method on. My filter is DE and runs about 9 hours a day. It rained last night and my readings with my taylor K-2005 test kit this morning were
    FC-3
    TC-3
    PH-7.5
    TA-100
    CH-80
    Borates- 0
    Temp 84F
    Based on the pool calculator I should add 3 cups 7oz of bleach to increase chlorine. Should I do anything about increasing CH and borates? or what would be recommended I add?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Asking About Levels
    What your FC level should be is entirely dependent on your CYA level. What is that at? How are you testing?
    CH depends on your pool surface. What type of pool do you have? Please update your forum signature with your pool details. Edit Signature
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yes, CH needs to come up to at least 250 ppm.
    More here on levels, Pool School - Recommended Levels
    More here on what to put in your sig and how to do it.
    Pool School - Read This Before You Post
    Apr 2016
    Houston, TX
    23
    FC was tested on my taylor K2005 test kit. CYA is at 40. Pool service is kinda rough so i'd say its plaster, pool is inground
    How can I increase my CH?
    15000 Gallon, Taylor K-2005 Test Kit, DE Pentair filter.
    DFW, TX
    24,497
    More here on pool chems, Pool School - Recommended Pool Chemicals
    Yes, likely plaster. Although, we drove through Houston recently and there were lots of fiberglass pool shops on 45. Post a pic and we can tell for sure.
    Apr 2016
    Houston, TX
    23
    Based on my CH reading this morning it was at 90. The calculator shows I should add 29Lbs of calcium to bring it up. Does that sound about right?
    DFW, TX
    24,497
    Yes, if your pool is plaster raise CH to 250 ppm or so.
