Thread: Timers for Sand Filter Pump?????????????????
    aflacduck's Avatar
    May 2009
    Central Mississippi
    I have a hayward sand filter pump and have been running 24/7 the past couple of years. Someone mentioned to me that I need to put it on a timer. Does anyone run a timer on their filter pump and if so how many times a day should I set it to come on and how long should it run on each cycle? Thanks for the help.
    22K gallons, 1 HP pump, Hayward Sand filter and Polaris Robot Cleaning System. IG 16x36 with Vinyl
    Hot Springs 5 Person Spa, 355 gallons using a Spa Frog for Chemical Distribution
    Re: Timers for Sand Filter Pump?????????????????
    Most people have a timer. How you setup the timer has a lot to do with the relative size of your pump and pool and with personal preference. You can find some information about determining total run time in this article at Pool School
    Aug 2008
    Conway SC
    Majority of all pool wiring I do, Customers request timers.. Mostly so they don't have to worry about starting and stopping the pump especially if they go away.
    17000 Gallons (16x32) Vinyl In Ground Pool
    Sand Filter
    Install "Finish Date" July 30 2014"
    Propane heater installed.. Used for 1 day.
    City Water.
