Thread: Hairline crack in above ground pool skimmer
    May 2013
    Bensalem, PA
    13
    The other day I noticed that there was a small amount of water leaking from the wall skimmer on my above ground pool. The hairline crack is about 1 1/4" long and runs vertically in the center of the outside portion of the skimmer. The skimmer is not exactly old, I think I replaced it about 4 years ago.
    I'd prefer to replace the entire skimmer at the end of the season when I close the pool, but is it possible to fix the leak for a few months?
    What is the best method and product to use?
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Re: Hairline crack in above ground pool skimmer
    Silicone RTV. Get the clear stuff, wipe it on thin and no one'll ever know. The skimmer isn't under pressure, so you can do it and call it a completed repair, no new skimmer necessary.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,778
    Better yet get a small tube of white 3M 5200 marine sealant. It will cure even when wet and is designed to be used under the waterline of a boat. Use a latex/nitrle glove when you apply it. It wont come off your skin without acetone or a similar solvent.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
