Thread: Large algae growth
    Large algae growth
    I have an in ground pool that hasn't been opened in 2 years. I had someone out to look at it and they said that there was too much algae in the bottom of the pool to save the water. I'm wondering if I work dilightly at getting most of the algae out can I save the water and not have to drain?
    Kim
    Inground Pool with vinyl surface
    ~30,000 gal
    Hayward pump
    Sand filter
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Large algae growth
    More than likely, yes; depends on what's in the water. Do you have one of the recommended test kits?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Check CYA level. You may have to drain (some, not all) based on that. Otherwise, you can most certainly conquer Algae by working diligently. It will be a process however. If it's truly that bad, probably makes sense to do a little of both (partial drain and hard work). Good luck.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
