Thread: Test for metals?
    May 2014
    MILLSTONE TOWNSHIP, NJ
    87
    Test for metals?
    Am a convert to TFP and using test kit...however, how do I test for metals?
    Thx!!
    33,000 gals, DE, IG, plaster, Purex Triton FNSP 60 filter, Pentair Super Flo 2hp, Pentair MinMax Heater
    Jun 2014
    15,093
    Re: Test for metals?
    You will find some products on-line like THIS ONE, but they can get pricy quickly. Because metal testing products tend to be more expensive, this is one of the rare times we usually recommend just having your water tested at the pool store. It's a good idea to also have the "source" water tested before adding chlorine to it because the chlorine may cause the metal to precipitate-out and skew the results.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Are yo on a well or ave a water supply with known metals, or are you looking to rule those out?
    Here's a cheaper, but slightly less sensitive kit - for $18 Amazon.com: LaMotte 2994 Insta-Test Iron and Copper Multi-Factor Test Strip Kit, 0-5ppm Iron Range, 0-3ppm Copper Range, 25 Count Tubes: Industrial Scientific
    This kit used to require tablets to dissolve sequestered iron and get a true read, but now is instant. I can confirm that it works properly on raw well water as now using it matches my pro analysis of well.
    All metal tests are a bit dodgy when it comes to trace amounts in pool water, especially if you use sequestrant, which cases the sequestered portion of the metal not to read. This kit, compared with its former tablet kit, reads my iron about .1 ppm lower than the week prior. Could be that I'm more sequestered or could be that its less sensitive.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    May 2014
    87
    Quote Originally Posted by Swampwoman View Post
    Well water....overall just simply want to make sure there are no metals in the pool as a preventive measure....
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    The strips should be fine. Test your fill water from the hose, then test the pool. If hose reads and pool says 0, just know that's likely skewed due to sequestrant
    Helpful Links:
