Thread: Filter Pressure Gauage
    Jun 2016
    Ontario
    1
    Hi everyone,
    Bought a used pool. Tried replacing the pressure gauge. I picked up one from the pool store and tried screwing it and and it doesn't seem like the threads are grabbing and I can pull it out fairly easy(even with teflon tape). It's Jacuzzi 192C. Hard to tell if the plastic threads are stripped or the pressure gauge is the wrong size? Anyways the issue is that if this is really stripped on my filter what can I do? I read somewhere I could use JB Water Weld and some fittings to make a new connection point.
    Any help would be greatly appreciated.
    Jun 2014
    15,298
    Re: Filter Pressure Gauage
    In this case, it might be good to have a close-up picture of the area, and if you could update your signature with all of your equipment that would help readers as well so we can see what options might be available for your make/model filter. Thanks.
