Thread: LP testing results
    Jun 2016
    Overlea
    6
    LP testing results
    Good Morning all,
    I have visited LP more times that I ever thought I would and every time I go in, my bill is ridiculous. I did 5lbs of soda ash last week, only to be told that I need to 1. Put in 10lbs of soda ash...wait 4 hours and then 2. put in 10lbs of Alkalinity Up...wait 4 hours then it's safe to get in. My pool has a little Algae in it & they said it's because no one is using it...WHO IS GETTING IN THAT?
    Here are their test results
    FAC-0
    TAC-0
    CYA-100
    TA-0
    pH-6.0
    Base-30
    Copper-0
    Iron-0
    Can you tell me your thoughts and provide suggestions on getting my levels up/down? I have ordered a test kit and am awaiting it arrival.
    Thanks!
    Intex Ultra Frame 18 ft round 48 in deep and 7,600 gallons, Above Ground pool surface vinyl, Hayward Perflex® Extended-Cycle D.E pump & filter.
    Jun 2014
    15,255
    Re: LP testing results
    Hello Natty! Unfortunately, no one here will be comfortable giving you directions forward based on those pool store tests. As you have just learned, they are of no help in fixing your pool. The good thing is you have made the right choice to take charge of your pool and order the proper test kit. Make sure to add that kit to your signature too okay!
    For now, don't add anything to your pool except about 1/2 gallon of bleach each day. That's just to try and keep algae from getting any worse. Now I will give you this heads-up info .... "IF" your CYA is as high as the pool store says (and it may be even higher), the only way to lower a high CYA (which came from pool store products b the way) is to do a partial drain of water. We'll confirm that with your kit, I just want you to be aware of it. Things like bags of shock and chlorine tablets are the main culprit of high CYA.
    Once your kit arrives, post a full set of results and we'll be glad to get you going. Very happy you joined us.
    Jul 2014
    Hope Mills, NC
    569
    With a pH of 6.0, you could use your pool water as an industrial solvent to remove paint. 6.0 pH is quite dangerous.
    However, since pool stores are criminally bad, we simply don't believe anything they say.
    Unfortunately, the only real answer is to get a reputable test kit and do it all yourself.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Jun 2016
    Overlea
    6
    Thanks for your responses...I have another question. My pool pump seems to pump (with force) for about an hour and then barely moves the water. I feel like i'm wasting electricity because I leave it on all day and night. You can hear it but don't see any movement(or very little) does it make sense to keep it on while I await the test kit?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Is the water clearish or full of "stuff"? If your filter is clogging that would explain it. Do you have a pressure gauge? If so how does it behave? I'm not very familiar with DE filters, but there is an article in Pool School on their cleaning and use.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Yep, nothing clogs a filter faster than algae, especially a DE filter. Need to backwash when the pressure rises 20-25%.
    Pool School - Maintenance and Cleaning of Pool Filters
