Thread: Newbie conversion question
    Jun 2016
    Vancouver, WA
    1
    Hi. 5000 gallon above ground pool set up with Baquacil out of the box last summer. Want to switch to chlorine.
    Completely drained pool for winter. It completely filled with rainwater this winter, and I drained it and it sat dry for a few weeks. Some silt, leaves and pink growth on liner.
    Filled it about 5 inches deep and added some bleach and scrubbed the liner. Drained. Rinsed. Drained. Liner is sparkly clean.
    Filling with water as I type.
    Do I need to change the sand in my sand filter? (Actually that crushed recycled glass medium). Or can I just backwash it really well?
    Anything else I might need to be aware of if I just set the pool up with chlorine this summer?
    Thanks!
    Aug 2014
    Northern IL
    4,615
    Re: Newbie conversion question
    Backwash when your pressure rises 10% over clean psi. Not a fan of glass, but, let's see how it goes.
    How are you testing that nice new water? Here is how WE do it with home testing:
    Pool School - Test Kits Compared
    If you decide to use TFP methods and get a testkit, add a half a jug of regular, unscented bleach everyday u til your testkit arrives.
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    433
    Quote Originally Posted by btbt View Post
    The media likely has baquacil residue on it, and if it was sand, the TFP conversion process would be to change it. Not sure w/glass. In any case I would at least backwash it before using it to filter the pool water. Maybe doing it with shock level FC from the TFP FC/CYA chart. Be sure the b/w hose drains somewhere that wont be damaged from any baquacil conversion goo or high chlorine. You might want to wait for a moderator or expert to chime in with their advice. I converted my pool this year and then switched from sand to glass (which i am a fan of).
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    462
    What's the definition of "backwash real well?" How will you know if you get all of it? When you backwash, it goes to waste. How much is fill water + Not knowing if your tank is BQ free vs. new medium + peace of mind? I'd go with the latter. You've made the conversion. No reason to cut corners now.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
