Results 1 to 9 of 9
Thread: Sand v zeolite
    Jun 2016
    Beaufort, SC
    10
    Sand v zeolite
    I just replaced 325 lbs of sand with 175 lbs of zeolite (as labeled) per recommendation from my Leslie's pool store guy. No trouble doing it, laterals are ok, but I am now getting fine black dust in the pool. It seems to happen when I set to filter after backwash/rinse, but may be happening continuously with pump running. It has been about 5 hrs since I installed the zeolite. Any thoughts? Could it possibly be residual debris from the pipes? It had been about 6 years since the sand was changed, and I was getting this same dust discharge, which was due to "channeling" (also per my pool store guy). They suggested adding cellulose fiber to force the temporary breakup of the channels. This worked great for a while (about 2 weeks) but when it returned I figured it was time to replace the filter media...
    1211
    In-ground, vinyl liner, approx 23000 gal, 18x36 Grecian 7.5 ft deep, 2hp pump running 24/7, t60 Pintair Tegalus filter rated for 325 lbs sand, salt system usually set to 25-30%, Dolphin Diagnostic robot that I run approx once per week, use PhosFree approx three caps full approx once per week.
    1211
    38,246
    Re: Sand v zeolite
    Welcome to TFP!
    We tend to not recommend sand alternatives as they seem to cause more problems. And the solution to channeling is a simple deep cleaning (see article in Pool School). Sand never wears out and very rarely need to be replaced.
    Jun 2016
    Beaufort, SC
    10
    Re: Sand v zeolite
    So is my only solution to remove the zeolite and go back to sand? Is there a chance this might clear up?
    1211
    1211
    38,246
    Re: Sand v zeolite
    Not sure. There are very few members with any experience with it. Maybe you will get some more responses. Did you try searching the forum for other related threads?
    Jun 2016
    Beaufort, SC
    10
    Re: Sand v zeolite
    I'm new to this site. I scanned for related topics but probably did not do an exhaustive search.
    1211
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Sand v zeolite
    There is a search box in the upper right corner.
    Jun 2016
    Beaufort, SC
    10
    Filter media discharge
    What could cause filter media (zeolite) to discharge into the pool. The laterals look fine. I changed from sand a day ago and since then a black dust-like substance has been collecting at the bottom of the pool.
    1211
    DFW, TX
    24,450
    Re: Sand v zeolite
    I did a search just for fun and there are quite a few threads that mention the zeo being dusty from processing and handling and putting dust into the pool. Did the instructions say to rinse the media first? I would probably vacuum it to waste to get it out of the pool.
    JoyfulNoise's Avatar
    May 2015
    13,175
    Sand v zeolite
    Quote Originally Posted by pooldv View Post
    pooldv is correct. Did you rinse/backwash the zeolite several times before turning the multiport to filter mode?
    Is the zeolite you used naturally mined or industrially formed?
    Zeolite is essentially a broad class of aluminosilicate compounds with porous 3D structure. Industrially formed zeolite can be carefully made to exhibit a single microstructure type. Natural zeolites are less exact and typically contain lots of impurities as well as quarrying dust and debris.
    Matt
