Results 1 to 13 of 13
Thread: Site Prep for Intex Ultra Frame AG
    May 2016
    Seattle WA
    15
    Doing the research on getting the ground ready to assemble a pool and Intex is giving different information depending on where you look.
    I have a site scraped of sod and will be having a pro level it. I'm a bit confused though on the support pads that go under the u-shaped brackets. The manual calls for a piece of pressure treated wood 15x15x1.2" under each one, flush with the ground. The local pool place doesn't have anything like that, so I was going to make my own using two 16" lengths of 2x6 side by side (I hope that makes sense).
    Today I watched the instructional video, where they just say if the surface isn't solid you have to place something under the brackets. Then in the video they show people putting it up on a grass lawn! They didn't even bother to mow it.
    SO, Intex above-grounders, what do you have under your brackets?
    Thanks!
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    Re: Site Prep for Intex Ultra Frame AG
    Mostly everybody uses concrete pavers under the legs.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Jun 2015
    Stockholm, Sweden
    250
    Concrete pavers, at least 2" thick, 4" if you want to be sure they dont crack.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Oct 2013
    Bellingham, wa
    10
    I'm having trouble locating 4" thick pavers. Would stacking 2" work? Or better to put two 8"x16"x4" side-by-side?
    jmcdtucson's Avatar
    Jun 2014
    317
    We got 4" pavers at Lowe's. I haven't done the math, but I'm guessing stacking 2" pavers would be pretty close as long as they sit on each other with no gaps.
    You can pretty much ignore the instructional video
    Are you going to put foam under the pool? It makes a nice surface.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Oct 2013
    Bellingham, wa
    10
    Yes, jmctucson, thinking of going with 1" extruded polystyrene sheets, double-taping the seams with gorilla tape. The lawn is perfectly level, so I was planning on laying out the included ground cloth, then the taped foam sheets, then a gorilla pad. Can't seem to locate 16"x16"x4" pads for the frames...
    Supermommys4's Avatar
    May 2016
    Independence, Missouri
    41
    That's what I just did! FYI "taping the seams" is a nightmare.
    We have a 15'x48" Pro Series above ground pool - with salt water filter system!!! Year 7 and I'm trying to get more creative ... Really wish we could keep it up year round!
    May 2016
    41
    Quote Originally Posted by Supermommys4 View Post
    https://www.menards.com/main/buildin...14816739160440
    May 2017
    Groveton, Tx
    34
    The 4" thick ones aren't called pavers, they're called blocks. I had issues finding them also since I was calling it the wrong thing.lol. Search for the measurements 4 x 8 x 16. They're only $1.40each at Home Depot. Lowe's is over $3. That makes a huge difference when you're buying 24 of them!
    Oct 2013
    Bellingham, wa
    10
    Any sage advice Supermommys4?
    Hopefully within 2 weeks of 5/21/2017
    Intex 16x32x52" Ultra Frame Rectangular Pool 14,364 Gallons
    Intex 2,800 gallon per hour Krystal Clear Sand Filter Pump
    Intex Saltwater system
    Hayward H300FDN Universal H-Series, Low NOx, 300,000 BTU, Natural Gas heater
    Oct 2013
    Bellingham, wa
    10
    Yes, I finally found them too! Are you planning on placing them side-by-side to equal 16" on each side?
    May 2016
    41
    No new updates as of right now davidpoll! I'm short on foam board as of right now- I'll update as soon as I get 2 more pieces and let you know!
    As of right now, I am planning on putting my uprights on top of the board which will be on top of my concrete blocks. I used 4" retaining wall blocks to cover the perimeter of my pool site.
    May 2017
    Groveton, Tx
    34
    No, I'm just going to place them under each poll, assuming the bottom of the poles are 16 inches or less.
    Hopefully by 6/01/2017... 16x32x52 Intex Ultra Frame submerged 2 1/2 feet in ground Krystal Klear Saltwater Generator
