Thread: Sand PSI Pressure
    Jun 2016
    Jackson NJ
    97
    Sand PSI Pressure
    Is 18 PSI starting pressure too high for sand filter?
    Vinyl IG 18x43 25,000 gallon
    Hayward Pro s244T 300 lb Sand (with occasional addition of clarifier)
    1.5 HP pump; Polaris 380 with booster pump; Hayward H400 gas heater
    TF-100 with SpeedSTIR
    Jun 2014
    15,285
    Re: Sand PSI Pressure
    Possibly, but two other things come to mind when evaluating a system's pressure:
    1 - Could the gauge be malfunctioning? Does it fall to zero when the system is off?
    2 - Is that 18 psi right after the filter was cleaned/backwashed?
    One other thing to consider ... when was the last time the sand was deep cleaned? Deep Cleaning a Sand Filter If you've not done it in a while it's possible that the sand is compacted and effecting your flow rate.
    Hope this helps.
    Jun 2016
    Jackson NJ
    97
    Actually, the sand filter is brand new as the pool company replaced the old DE filter. From Day One it started at 18 PSI clean. Just hoping this is not a problem.
