Thread: wondering about chlorine consumption
    Oct 2015
    Rancho Cordova CA
    9
    Started a SLAM Saturday. Up to last night the water was green and I could barely see the bottom. This morning the green was gone and water was clear. I am adding Chlorine per the chart here based on the FC amount tested. So, I need to maintain 16 PPM based on my CYA. I tested just now and I do it twice per day and I'm down to 8PPM. The water looks good. I'm wondering what is consuming all the Chlorine? I'm not seeing algae anywhere. I cleaned the filters Sunday. Is it possible they need to be cleaned again?
    Greg ~ My pool: Plaster, 19,500 Gal Century V-Green 165 variable pump 1.65HP; Pentair Clean and ClearCtg filter; Polairs 380 with 1/2hp booster pump. Taylor K-2006
    38,301
    Re: wondering about chlorine consumption
    Has the pressure on the filter gone up? You need to clean it whenever the pressure rises 20-25% over the clean pressure.
    You will lose a higher # of ppm of FC to the sun, the higher the FC is. So that is part of the loss, and there is still likely some algae in the water.
    Oct 2015
    Rancho Cordova CA
    9
    how long with clear water and no sign of Algae do I bring it up to 16PPM?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Until you pass all three tests
    Clear water
    Cc of less than .5
    OCLT of less than 1
    OCLT = overnight free chlorine loss test.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
