Results 1 to 8 of 8
Thread: High chlorine, pool still green
    Jun 2016
    Jackson NJ
    97
    My pool has been green since opening, although the water did clear alot and the green is lighter, but still there. Here are the numbers according to TF-100, is there anything here that accounts for the green?
    FC 21
    CC 0
    CH 150
    TA 120
    PH 7.6 (after 30 seconds color darkened to 8.2,which reading should I use?)
    CYA 0-10
    Also, the according to the measurements on the website, the pool is about 30,000 gallons. But I found the original documents from when the pool was installed and it shows volume of 24.300! Which do I use?
    Thanks
    Jun 2012
    Butler, PA
    336
    Re: High chlorine, pool still green
    I am sure you will be asked to put your specific pool details in your signature so people helping can see what you have. While you figure that out there are instructions for doing so on the forum, edit and add them above in your original post, then do the official signature.
    There is an abundance of detail that accounts for the green, nothing that can't be rectified, but with no CYA and that high FC you need to get your details listed so someone can get you sorted.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    Jun 2016
    Jackson NJ
    97
    Ok. This is an in ground 18x43 (18x34x43) lazy el pool. 30,000 gallon although documents list as 24,300 gallon, so not sure.
    300 lb sand filter, 1.5 HP
    2-3 hrs sun
    Jun 2012
    Butler, PA
    336
    is there a liner in it?
    Full Sun ~ All Day
    Jun 2016
    Jackson NJ
    97
    Vinyl IG 18x43 25,000 gallon
    Hayward Pro s244T 300 lb Sand (with occasional addition of clarifier)
    1.5 HP pump; Polaris 380 with booster pump; Hayward H400 gas heater
    TF-100 with SpeedSTIR
    Jun 2012
    Butler, PA
    336
    You need to get stabilizer in the pool, your Free Chlorine is a bit high for your current reading of 21.
    I believe they recommend starting at 30, I am not an expert, just a forum participant ~ but I do know you will be advised to bring that up.
    Your pH is high, but I believe that is due to the free chlorine you have in there currently.
    Liquid stabilizer goes in right in front of the return, granular you can put in a tube sock, nylon, pair of tights and allow it to dangle in front of the return.
    With that vinyl liner you'll want to get on that so the stabilizer protects the liner from all that chlorine.
    Between now and then someone in the know will be in here to assist you, but you won't be making a mistake letting that FC drift down a bit while you bring up the stabilizer.
    Full Sun ~ All Day
    Jun 2014
    15,070
    Hello again! Those are some pretty good notes above. In preparation for your SLAM, you definitely need a minimum CYA of 30. So you may want to add about 20 ppm worth or stabilizer if you believe there is some currently in the water.
    To increase CYA via granular stabilizer, place the required amount as calculated by the Poolmath calculator into a white sock and place in the poolside skimmer basket. For those concerned about suction flow to the pump, suspending the sock near a return jet or from a floating device will also suffice. Best never to allow undissolved granules to rest directly against the pool surface. Squeeze the sock periodically to help it dissipate. Once dissolved, consider your CYA adjusted to that programmed (target) level. CYA test readings should show a rise in 24-48 hours, however some pools may experience a longer delay to fully register. Best to confirm final CYA in about 5-7 days before adding any more stabilizer/conditioner.
    pH needs to be lowered to about 7.2. Read immediately after adding the 5 drops. Most reagents begin to change after they sit. Lastly, maintain your FC at "12" - that's based on a CYA that will be adjusted to 30. If you find later in a few days that your CYA is way off (from 30) let us know and we'll help you adjust.
    So, CYA of 30, pH of 7.2, and FC of 12 ... then "SLAM" (link below). Good luck!
    Jun 2016
    Jackson NJ
    97
    Thanks all.
