Results 1 to 7 of 7
Thread: Illinois DIY Pool Build 2016
    May 2016
    Rushville, IL
    8
    I've been peeking through some of the threads on this site for a while now.....My husband and I are in week 8 of our DIY Concrete block pool. I was looking for some advice on skimmers. How to correctly fit one? What is the best way to attach the skimmer??
    I have looked at several wide mouth skimmers, I am finding that the depth of the skimmer is sometimes not included in the dimensions. Looking to gather some knowledge from you pool veterans out there!
    Thank you - Brook
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Re: Illinois DIY Pool Build 2016
    That picture looks familiar.
    I used a Hayward SP10712SFVA. I installed two, in the top layer of block. I then added treated 2x6 on top of the top block layer around the entire pool, which I screwed my aluminum coping into. The depth of the skimmer mouth was perfect to fit on the 2nd layer (from the top) block, 6" depth. I think I had some 'foam' sill seal laying around, I lined the outside of the skimmer mouth with just to give it a snug fit, but once the 2x6 went on top, it wasn't going to move. It fit right between two blocks, about 16" if I remember right.
    At first I wished it had a wider mouth, but now I am quite happy with it,, it has a taller opening so on the prolonged hot days you don't have to refill the pool as often.
    I built a plywood housing behind the skimmer and filled it with concrete. Just make sure you support that gob of concrete, I drilled a couple pieces of rebar into the back of the wall (just above where the plumbing connecgts to the skimmer bottom) for the concrete to adhere to. I haven't had any problems with them. Seem to be of decent quality.
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    30,403
    A couple of skimmer pics here.
    An unusual pool build
    May 2016
    Rushville, IL
    8
    dw9000,
    Thank you for your information. I just want to clarify. You used this skimmer above ground, but built a concrete "house" around it?
    Brook
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Quote Originally Posted by bdawson View Post
    dw9000,
    Brook
    Well the top 'lid' of the skimmer is even with my pool deck. They make an extension neck for that skimmer, I bought so I had a little more room when they poured the concrete deck. In hind site I really didn't need too.
    The top 'of the throat' of the skimmer (that rectangular opening to the pool) was even with the top side of the top layer of block. I wrapped it in seal seal foam, for a tight fit.
    I ran 2x6 around the entire top layer of block and that went right above the skimmer throat and it kept it in place very tightly. I suppose you could run your copping right over it and achieve something similarily if you weren't using 2x6, and when you finish the deck you could backfill with concrete/mortar from behind the top of the skimmer... I just remembered, I also anchored the skimmer into the concrete wall with some tapcons.
    I did sort of like what duraleigh did in his skimmer pictures, I built a plywood structure on the outside of the pool wall and encrusted the entire skimmer (except the top 5" where the pool deck concrete would meet) in concrete,, took a couple 80lb bags. The structure wasn't anything fancy, I did it while I was backfilling with stone. I put 3 pieces of plywood up, and backfilled to keep it in place, then I poured in mixed concrete. I didn't backfill anymore that I had to, just to keep the plywood upright,, and when it dried I peeled the plywood out, and continued backfilling
    Pic before deck (after backfill, skimmer's in place, and coping up)
    https://s32.postimg.org/z61ldt3n9/100_0159.jpg
    Pic after deck
    https://s31.postimg.org/6cwa68mcr/IMG_1411.jpg
    You can buy this skimmer, if you google it, for $70 or so. You could take a couple of your extra blocks (on the side) and see how it would fit, I think it would work for you.
    Cartridge Filter
    May 2016
    Rushville, IL
    8
    This will not be built into a concrete deck, but can be supported as such (my husband is a very skilled carpenter .....Do you think it will still work?
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Sure, you could still case it in concrete for protection and either backfill around it or build a wooden deck or whatever around it.
    Cartridge Filter
